setting front a-arm angle ?
Im rebuilding the front suspension on my hotrod 911S. Going to sander 22mm front t-bars, custom valved bilstein struts with raised spindles, smart racing products front anti-roll bars, elephant mono-balls and strut brace.
Its time to install the torsion bars and set the angle for ride height on the front a-arms. What angle to set the a-arms?
The car will only weight about 2000lb. It has a mag case engine and trans, but still not exactly sure on weight distribution front to rear.
I found via the search on this site a neat calculator to determine the angle on the rear spring plate for setting the rear torsion bars, but no such luck finding a tool to determine the angle for setting the front?
Anyone have any clue what a-arm angle I should start with? I was thinking 20 degrees.... but thats just a WAG.
Thanks for the help!
Terry
Old 11-04-2003, 11:18 AM
Irrationally exuberant
ChrisBennet's Avatar
The fronts are sooo easy to reset, just experiment. With 22mm front bars you will need to have the tire up some (not at full droop) before you put the cap on.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-04-2003, 11:53 AM
I was planning to set the a-arm angle, then install the torsion bars and caps before the strut is even mounted, much less a wheel and tire?
It seems that if the correct un-weighted angle of the a-arm can be estimated this would be pretty simple. Im just hoping to avoid many hours of trial and error re-indexing of the bars when the car is back together.
Terry
Terry
Old 11-04-2003, 01:22 PM
ditto
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-04-2003, 01:32 PM
Terry
The fronts are really easy. You just pull the cap of the end. Wait until you do it you'll see. The adjuster has lots of range so you don't have the splines nearly as close to perfect as you do on the back.
-Chris
Old 11-04-2003, 01:41 PM
I can see your right.... Ill just wait and install the torsion bars last. Ill put the wheel/tire on, raise the a-arm with the jack and when the wheel is in the correct position ill set the bar.
Another question.....
how important is the torsion bar seal? The diagrams show a rubber seal between the torsion bar and the adjuster cap. When I took my car apart, this was not there. I also have not seen anyone that carries them. Do guys always replace these?
Terry
Old 11-04-2003, 02:38 PM
CHILI's Avatar
Terry
That's funny! Well, maybe not. But, I put new T-bars on my car a few weeks ago and noticed the seal, too. Although it's foam, not rubber. Pelican carries them. I had to call, though. The shipping was more than the two seals.
But, I had to have them and didn't need anything else. I repeat. I didn't need anything else. Wow, I think I'm finally done!
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 11-04-2003, 03:34 PM
Regarding the seals...
I just went through this and based on a lot of earlier posts, I made my own.
The earlier posts referenced insulation foam and specifically foam that is "blocked" so air/moisture will not pass through. One person used wetsuit material as I recall.
I cheated and used an old mouse-pad (don't tell anyone)
Fritz
1987 944S
1973 911E
Old 11-04-2003, 04:07 PM
Normal A-arm angle is about 10 degrees. With raised spindles...who knows?
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-05-2003, 05:42 PM
