Gas pedal is too low... options?
I tried adjusting it tonight, having read that it was adjustable on here the other day. The widget that goes between the pedal and the actual mechanism in the pedal cluster is set as long as it goes, so there's no more adjustment there.
If I want the pedal higher, to get it closer to the height of the brake pedal, are there any other options I've got? Does anyone make replicas of that part that are longer?
I really like the looks of the adjustable pedals where you can put a side "thumb" of the gas pedal more below the brake pedal, but those are a lot of cash.
What other options are there?
1968 911L
2004 Dodge Dakota SLT Plus
Old 11-06-2003, 07:05 PM
Zeke's Avatar
Check the link under the car next to the transmission. It may have separated and is working only on it's safety catch. Looks like a little barrel about 6 inches from where the linkage exits the bulkhead.
Old 11-06-2003, 08:13 PM
Irrationally exuberant
ChrisBennet's Avatar
If you adjust the gas pedal up be aware that it will cause the linkage to hit the stop at the throttle body end if you don't adjust the linkage at the transmission. The consequences of not doing this is bent or bending throttle linkage.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-07-2003, 04:46 AM
Some of us don't have throttle bodies. I'm not entirely clear how this stuff all works with carbs, etc. I'm not going to mess with it right now, until I know for sure
1968 911L
Old 11-07-2003, 06:31 AM
You've already messed with it.
If you make the throttle linkage longer on one end (by raising the pedal), you need to make it shorter on the other end. The linkage has some springiness in it so you may be OK but if it stays bent the throttle won't close when you let off the gas.
-Chris
Old 11-07-2003, 06:35 AM
Have you checked the gas pedal itself? you have two (2) holes/points where the tip of the rod snaps in place. Try snapping it into the bottom hole!
Good luck!
p.s.,
The brake and clutch pedal heights are also adjustable.
Old 11-07-2003, 07:20 AM
A 1.5 inch thick block of soft wood cut to the same outline as the pedal, painted black, and screwed to the bottom of the old pedal.
It works
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-07-2003, 07:24 AM
cab83_750: thanks, I had no idea, I'll check that.
Didn't know the brake pedal height is adjustable too... got a link for explanation of whats involved?
My goal is just to get everything more in-line, so I have a chance of getting heel-toe working without breaking my ankle when I shift.
1968 911L
Old 11-07-2003, 07:25 AM
Is the pedal height a problem at the track? They usually line up when you are braking hard - harder than you would on the street.
-Chris
Old 11-07-2003, 07:28 AM
You underestimate how hard I brake on the street.
In actuality, I'd guess its probably okay if I'm driving that agressively, but I want something sort of in the middle. When I'm just idling around town, its not so important, but I want to be able to do it without risking someone rear-ending me. Sort of splitting the difference.
1968 911L
Old 11-07-2003, 07:57 AM
John Brandt's Avatar
you sure its not that your brake pedal is too HIGH?
Old 11-07-2003, 08:01 AM
Brake pedal matches clutch pedal.
1968 911L
Old 11-07-2003, 08:10 AM
Zeke's Avatar
One more thing. Start by checking if you are getting wide open throttle with pedal down. If not, something stretched. In my case, it was the anti vibration link. The old style just separated leaving you with no throttle. The replacement model has a housing that captures the thing if it breaks and gives you at least partial throttle.
Old 11-07-2003, 08:23 AM
CHILI's Avatar
You can check out what I did. It's cheap! about $4 total, looks stock and can be undone at the track in about 2 minutes.
911 pedals
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 11-07-2003, 09:55 AM
