ckissick's Avatar
Well, having just read all of the above, I'm leaning toward the Webers and SSI. Why? I have a good situation. I have the Webers and SSI's in the '74 engine that's coming out. Both engines will be out of the car for easy work. The new engine is a '78, so I have the right distributer. I love the subjective stuff, such as the sound and the throttle response. I like the clean look in the engine bay of a 1970 911E. Cold starts on the coast of CA are not an issue. The list goes on. I'm with Chuck on this one. Anybody want to buy a CSI unit? How about a torn down, worn out '74 2.7L?
Charlie
Old 11-09-2003, 10:08 AM
Cool
Originally posted by Mukilteo911
I can not figure out why since the place I am getting my vacume is closer to the vacume source than with the cis set up.
Big Big overlap cams are usually a problem with power brakes.. Our 911 E-cam doesn't have that kind of overlap. Even thou it's considered big in our engines.
If that's not your situation then maybe the booster to hose rubber fitting is dried out.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-09-2003, 04:15 PM
Cool
Originally posted by ckissick
[B]Well, having just read all of the above, I'm leaning toward the Webers and SSI. /B]
cool
I love carbs even thou it's not as efficent thru the rpm band.. Then again WOT is WOT no matter what's used.
My fantasy would be for Superman to fly behind my car with a 55 gal drum dumping metered fuel right into the intakes.
So I'm gonna be carb possessed pretty soon.....Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-09-2003, 04:23 PM
