Regenerated User
72doug2,2S's Avatar
If I can show you a picture can you identify the pistons as E or S?
I seem to be bad at attaching pictures but here is the link
The pistons
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 11-11-2003, 02:03 PM
dtw dtw is offline
GAFB
Those look like 2.2E pistons to me. Let me get home and I'll send you a photo of a 2.2E piston. Keep in mind that after 30-something years, an engine type number is no guarantee of what's actually in the engine.
A quick search would have revealed debates on valve clearance and expert guidance. Such as:
Valve clearance: 1.5mm+ intake and 1.70 exhaust
Summary: Some say 1.5/2.0, some say 1.5/1.5. Generally not an issue when using stock pistons and cams in stock combinations, with original deck height.
Please tell me that's a photo of disassembly, not assembly.
Several BMWs
Old 11-11-2003, 02:35 PM
I concur,
The pistons look a lot like my E's.
Old 11-11-2003, 03:10 PM
Hilbilly Deluxe
emcon5's Avatar
Originally posted by 72doug2,2S
We can't do a real profile without another tear down. Can we avoid this. Does the stamped SE and S mean anything.
Nonsense.
Webcam, real or fake
Tom
82 911SC Coupe
GTI Cup #43
Old 11-11-2003, 04:09 PM
dtw dtw is offline
GAFB
Note the pic below. 2.2 E piston.
Sounds like you really need to reevaluate your mechanic situation. I'm a clueless newbie but I know how to time cams, look up timing specs, and ID pistons. If your wrench can't do the above, which I've learned from hanging out here, reading a few books, and tinkering with a few engines, then you really gotta wonder how he's going to build a reliable, leak-free engine.
Cheers
Several BMWs
Old 11-11-2003, 07:18 PM
Regenerated User
72doug2,2S's Avatar
Some additional info.
The MFI pump is the 2.2 S pump from the ID numbers on one of the plates (0408 126 009). So the case and pump says "S". The cams have no other markings other than SE and S.
Tonight my tech and I looked did another dial on the cam lift on the valves. After four turns around the dial the top lift on the intake showed .448 lift on cylinder 1. Tomorrow he will do the exhaust.
What kind of lift would an "E" cam give?
I found in an old box that the S engine swap was done on 12-10-82 by "The 911 Shop" in Mooresville N.C. for $200 labor. Wow, that was cheap. ???
I'll call and see if their still around for information on this engine.
'72 911T 2,2S motor
'76 BMW 2002
Old 11-13-2003, 07:03 PM
Regenerated User
72doug2,2S's Avatar
Again with the fresh information.
According to one of the linked posts in this post the early S cam
looked like this on lift. (FROM THAT EXCEL FILE)
INTAKE
11.36 MM (.44724 inches)
EXHAUST
10.05 MM (.39567inches)
I know my Intake is .448 inches and I'll see if I can get the Exhaust tonight.
So, I have an S case, S MFI, S Cams (likely), how can I be sure on the pistons? Does anyone have pitures of the early "S" pistons?
I know the 2.7 S is quite different, but what about the early "S"?
Could I have the cam upside down?
'72 911T 2,2S motor
'76 BMW 2002
Old 11-14-2003, 02:17 PM
dtw dtw is offline
GAFB
Public retraction! The pistons that I was given, and that I photographed for you in this thread, were described as "2.2E Pistons"
This is INCORRECT! I just helped tear apart a 2.2E today, and their domes and pockets fell neatly in between the piston I photographed for you, and my other set of 2.2T pistons.
You would appear to have 2.2S pistons after all! (Congrats).
Hope this helps. Sorry to have supplied inaccurate information.
Several BMWs
Old 11-16-2003, 06:43 PM
Regenerated User
72doug2,2S's Avatar
Hey, that is great news!
OK so, now the last question is the cam timing and why my guy thinks he can't time this engine into the S spec. I'll call me tech today.
Thanks,
Doug
'72 911T 2,2S motor
'76 BMW 2002
Old 11-17-2003, 04:06 AM
Regenerated User
72doug2,2S's Avatar
Here are the results timing the 2,2S
11/21/2003
Meas. Thous MM
ideal 0.205, 5.207
set 0.206, 5.232
both @ 360 degrees
Clearances (Piston to valve)
Meas. Thous MM
Intake 0.165, 4.191
Exhaust 0.167, 4.422
Lift Meas.
Intake 0.452, 11.48
Exhaust 0.402, 10.21
MFI Lines up perfect
What do you think?
'72 911T 2,2S motor
'76 BMW 2002
Old 11-21-2003, 11:17 AM
dtw dtw is offline
GAFB
Sounds peachy. Fire it up!
Several BMWs
Old 11-21-2003, 11:19 AM
