Engine Numbers HELP
Can someone please tell me what this is???
901/02 15552 (stamped on right of fan horizontal) *4081449 (Stamped on right side of fan vertical) Wating for your help Thanks
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com |
Mocha BAP
I could easily be wrong, but this is what I came up with :
901/02 67/68 911S Weber carbs 80x66, 1991cc I 42, E 38 I 36, E 35 9.8:1 160hp@6600rpm 132 lb/ft @ 5200rpm My guess is '68 based on your numbers, but again, maybe someone else will have some more difinitive info
Scott 71 911T Coupe 3.0 Looks stock 79 911SC Coupe 3.2ss Nothing stock 02 996 C2 Cab Mostly stock 06 955 CTTS Super P!G |
Bandwidth AbUser
Based on your engine serial number, you're looking at a '68 911S engine, not originally imported into the US.
Jim R. |
Thanks Guys
