thrown_hammer's Avatar
Supertrapp options
I am putting Bursch headers on my car. I see two options for Supertrapps.
Option 1:
Use these mufflers. Fab a short peice to bolt to the flanges on the headers. I think these my be too short?
Option 2:
Cut the headers back to the red line in the pic and use these mufflers clamped directly to the headers. I think these would muffle better.
Essentially Removing the length needed to mount up a stock muffler. I am getting the headers for a good price so I am not scared to cut on them.
Pros or cons to either option?
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 11-14-2003, 07:41 AM
Embs's Avatar
Supertrapps are very restrictive IMHO, unless you run them with no discs, then they are very loud. I think they are one of the worst mufflers you could put on a 911, especially a 3.6/3.8. I could not find a happy medium with Supertrapps. Try some flowmasters but use no larger than 2" outlets or the resonance will drive you crazy.
Old 11-14-2003, 07:51 AM
What about all the discs with open caps? I think that would flow good for my 3.2? I thought they would get more restrictive with less discs???
1975 911S (sold)
Old 11-14-2003, 07:56 AM
Embs's Avatar
When I said "run them with no discs" I meant the end cap included. Yes you are correct the more discs you insert, the more exhaust you flow, but you still have the nice shiny RESTRICTIVE end cap to hold it all in place. Supertrapps are trying to do to much in a limited amount of space. I have one supertrapp left, 24" I believe with an O2 bung welded in it. You can have it if you like, PM me an address and $5.00 for shipping.
Old 11-14-2003, 08:09 AM
Moses's Avatar
I personally don't like the way they sound. If you are going to cut the headers bach, you may have room for a set of Coast Fab mufflers. Sweet sound, no restriction.
Old 11-14-2003, 08:14 AM
Mr. Embs sir, you have a PM.
1975 911S (sold)
Old 11-14-2003, 08:20 AM
petevb's Avatar
Other options I'm considering- I have no direct experience with these:
http://www.spintechmufflers.com/spintech/spintechindex.asp
The "Pro street" from above. I'm thinking it might get me black flagged at laguna seca, though, if I used it alone. Light, and they might not look bad tucked up under the car and painted black.
Also: http://www.quiethorsepower.com/images/side%20914-6%20.JPG
Phase 9 mufflers. These might also be pretty light if the resonance box was removeable (for when I'm not at laguna). Anyone have pics of these for a 911?
I believe both of these have a pretty good db reduction to flow ratio, and they should reduce significant weight comared to almost anything else. I'd cut the headers down to fit them.
Pete
69 w 997 GT3 3.6L
Old 11-14-2003, 08:22 AM
IROC's Avatar
I ran Supertrapps for years on my 2.7 with "European Racing Headers". I ran 18 disks in them in lieu of the typical 12. I, personally, loved the sound.
Option 1 would cause blood to come out of your ears.
Option 2 is a better idea. It essentially replicates what I had.
Even with option 2, you'll be setting off car alarms on a regular basis. BTDT.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-14-2003, 08:24 AM
Embs, Thank you.
Option 2 it is.
1975 911S (sold)
Old 11-14-2003, 09:09 AM
dickster's Avatar
option 2 LOOKS a whole lot better than 1.
1 look very rice.
2 midly rice.
imho.
Rich
'86 coupe
"there you are"
Old 11-14-2003, 10:31 AM
Bill Verburg's Avatar
I've never thought much of Supertrappes either. Flowmaster or even better Coasts are the way to go. There are several east coast race car useing the Coasts they sound great!!
My Flowmaster/Fabiani had a slight resonance at 3.6l w/ B&B headers which went away at 3.8l same headers. Coasts sound better though.
Bill Verburg
Old 11-14-2003, 01:34 PM
petevb's Avatar
I like those Coasts, bill. Any idea what kind of dbs the guys that run those are putting out? I assume they do 2 of the longer ones?
69 w 997 GT3 3.6L
Old 11-14-2003, 04:25 PM
ttweed's Avatar
Here ya go. With the crosschamber silencer, these are under 92 db @ 50'.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 11-15-2003, 09:32 AM
petevb's Avatar
That pic would be for a 914, unless you've done some minor mods to you 911... I did find this, though:
Very nice, and you can make that back muffler removable depending on the track. Of course those custom headers look like they cost a fortune...
Old 11-15-2003, 11:18 AM
kellzey's Avatar
Coast Fabrication mufflers for 914-6 setup...
Qarl
Old 11-15-2003, 01:32 PM
RETIRED
Joe Bob's Avatar
16 discs on each side, crossed with sport cats in between....I love them.....
2012 ML350 3.0 Turbo Diesel
Old 11-15-2003, 01:48 PM
RETIRED
Joe Bob's Avatar
Oppsie, helps to have a pic.....
Old 11-15-2003, 01:50 PM
ttweed's Avatar
Ooops- absolutely correct- I have NOT done a mid-engine conversion on my 911, although I understand Fabcar will do such a thing for the right price. That pic was taken off the Rennlist from a thread discussing the Phase 9s.
The JWE/Peter Weber setup in SS was $3300 the last time I checked. I went with a mild steel version for less $$$ and had it JetHot-coated in flat black. It also has sleeved V-band clamped flanges instead of the 2-bolt diamond flanges as in the picture. Not as pretty as those, but my setup does work well. I just don't have any pics of it.
For tracks where there are no sound regs, I have straight pipe extensions that clamp on to the Phase 9s and the crosschamber is removed to save weight. They are over 100 db that way at full song with my carb'ed 3.4.
TT
Tom Tweed
R Gruppe #232
Old 11-15-2003, 02:27 PM
Moses's Avatar
Mike, Do the cats quiet down the supertrapps? How much?
Old 11-15-2003, 03:56 PM
RETIRED
Joe Bob's Avatar
Pretty significantly.....ask Hal Michaels "Halm" how it sounded...he stopped by after he picked his car up from Otto and I gave him a freeway ride.....had to get around a Corvette that was playing "pokey" on the onramp....
Old 11-15-2003, 03:59 PM
