67 911 calipers
having some difficulty locating calipers (rear) for a 67 911. these are solid rotors (not vented) or does one caliper fit either. would appreciate good mail order source.
dastier |
Try some of the 914 specialists. I'm not familiar w/ any, you'll need to do a search.
I think I have a pair from a 69 that had solid rotors. Do you want me to check ?
I like them I drive them |
sure...that would be great. if they will in fact fit ok. part of the problem is just finding cross ref numbers. the car i have (67 911) has been sitting idle and outside for about 3 years, so things are a little bound up and rusty. the brakes, rotors, calipers, etc. are just the tip. altho the body is very good. just the bare metal items really took a hit. let me know.
dastier |
I have them. Call me 206-351-6404
Those would be the Ate 'L' calipers on the '67. Check the mount spacing to see if the later 'M' rear calipers [3" spacing] can be fitted. If I recall correctly, the 'L' calipers used a more narrow spacing ...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
The m calipers wer just for vented rotors right ? These are for non vented rotors. Thomas post the numbers on your parts and any identifying markings
so we can compare.
No, there were 'M' calipers without a spacer between the halves for non-vented rotors ... your '69 'M' calipers should not have spacers, and have 3" center-to-center distance between the mounting ears. I believe the 'L' calipers had only around 2.3" between the mounting ears, center-to-center.
VW used the 'M' calipers with non-vented disks on Type 3 models thru '73 or '74.
rear calipers for 67 911
here's some descriptive bits. the old calipers i removed have ata stamped on them..it really may be ate. very crusty and hard to see. the mounting holes measure 2.25" cntr to cntr.
hole size is .39" calipers are 4.72" side to side calipers are 5.30" front to back could find no number, but the rubber dust seal had the following: ata (or ate) 3004.1 44473 3-11. the back calipers are noticebly smaller than the front. hope this narrows it down some. tom
dastier |
Tom,
Sounds like the Ate 'L' calipers I remember ... spacing and M10 bolts nails it!
OK, now we know for sure mine are not the same, oh well. I suggest you yours rebuilt. Happy braking.
We can rebuild em
Racing Porsche for over 30 years. http://www.OttosVenice.com Check out the Porsche Owners Club Track event Videos |
ok....that is an option i have been considering. but haden't too much since i still held hope of just buying some. but..i had resigned myself to at least lining up someone to help or do some rebuilds. so, for starters, whats my cost should i decide to send these puppies off to you? that's 2 rear calipers.
tom
dastier |
Thomas,
I should have a pair. I upgraded my 67 911 normale front suspension with a complete 78 SC front suspension including S calipers and Bilsteins last year. My brakes were previously non-vented. Feel free to make me an offer for the pair. |
try 20th street auto
1967 912 2.7 1977 MGB (bright yellow) 1985 Honda Spree Moped (great for towing rollerbladers) A flute without holes, is not a flute. A donut without a hole, is a Danish. |
