Send a message via Yahoo to RichMason
Rustproofing inside of torsion bar tube - how?
As part of the ongoing chemo on my 69 Targa, I have the rear suspension removed completely, including the torsion bars. Inside the tube, there is surface rust all over it, with some flakes collected at the ends. Any suggestions as to how I can effectively rustproof this? I do not have a rotisserie set-up so rotating it 90 degrees and filling the torsion tube is not really an option. Does anyone make large round wire brushes (4 inch diameter?).
Rich Mason
87 951 for sale $5500
Old 11-19-2003, 05:37 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Use Black oil a KEP product, it is what truckers use on the 5th wheel. It is heavy oil that foams up when you spray it, just spray in the tube and you will be set. Steve
Old 11-19-2003, 05:43 PM
Platinum Member
dad911's Avatar
chimmney sweep brushes at the local home depo? Or a 4" wire wheel bolted to a threaded rod?
Old 11-19-2003, 06:19 PM
Great suggestions. Thanks guys.
Rich Mason
Old 11-20-2003, 06:25 AM
Cool
If it was mine I think I would
wire brush the tube
seal one end
seal other end with a 1/2 clear tube attached
fill with white vinegar to cure steel
flush with water
Por-15
I'm not sure if spring tube is a sealed tube
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-20-2003, 07:58 AM
