BURN-BROS's Avatar
3.3 Muffler Bearing
......No, really what do parts 3 through 9 do? Any turbo guys know?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-22-2003, 02:44 PM
That is the compressor bypass vavle. It diverts the turbos compressed air when the motor sees high vacume. ie between shifts and at idle
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-22-2003, 04:23 PM
beepbeep's Avatar
It's recirculating "blow off valve"...the thing that goes "pshhhh" in ricer movies but plumbed to channel air back in. Those seals usually dry out and need replacing...other than that, it's bulletproof.
Thank you for your time,
Old 11-22-2003, 05:15 PM
350HP930's Avatar
Muffler bearing? LOL
Old 11-22-2003, 05:17 PM
Cymru am Byth
carmad's Avatar
I had the seals disintegrate (7) which caused the piston (3) to stick in the housing. This resulted in no boost.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 11-23-2003, 05:34 AM
beepbeep's Avatar
Yeah, it's typical problem...i changed them as well...
Old 11-23-2003, 06:09 AM
Did you get the memo?
onewhippedpuppy's Avatar
I heard changing them requires a skyhook.
‘07 Mazda RX8-8
Old 11-23-2003, 07:00 AM
beepbeep's Avatar
No, you can do it with ordinary tools in two hours. Here are some pics:
Changing 930 dump-gaskets, pictures galore
Old 11-23-2003, 08:18 AM
Finally a picture! Now I can order my missing muffler bearing, and I was beginning to think you guys were joking. Do you have the part#?
72 Porsche 911T/E Targa
72 Porsche 911S
85 BMW 735i
Old 11-23-2003, 08:22 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Make sure you get the pre-lubed high speed muffler bearing! LOL
Bob
Bob Hutson
Old 11-23-2003, 08:38 AM
BURN-BROS's Avatar
Thanks for all the feedback guys! Now all I have to do is find where I refill the blinker fluid.....
Burnham Performance
Old 11-23-2003, 09:08 AM
Cymru am Byth
carmad's Avatar
Part no 930 110 149 00, you'll need two.
Julian Williams
Old 11-23-2003, 02:13 PM
HawgRyder's Avatar
Burn...have you upgraded to the new flint ignition yet?
Also...I hear Dribble Injectors has a bigger setup for Porsche.
Bob
Bob Hutson
Old 11-23-2003, 04:03 PM
I see these cheap as dirt at Pamono all the time. Don't let anyone tell you they're expensive.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 11-24-2003, 08:21 AM
BURN-BROS's Avatar
LOL, Hawg I will upgrade to the flint when they make them waterproof!
Burnham Performance
Old 11-24-2003, 08:52 AM
Senior Member
Superman's Avatar
I upgraded to the ceramic muffler bearings, and it has made all the difference.
Mocha 1978 911SC. "Coco"
Old 11-24-2003, 09:14 AM
JC930's Avatar
It's ok to go ceramic if it is the vapor blasted carbon impregnated verity.
jc930
77' 930 turbo carrera silver SOLD
03' SL500 Mercedes Benz white
06' GMC Yukon Danali white
15' LTZ Chevy Suburban black
07' 997 tt black
Old 11-24-2003, 09:26 AM
