-   -   3.6 Install - It's Alive! (http://forums.pelicanparts.com/porsche-911-technical-forum/137670-3-6-install-its-alive.html)
ohecht 12-23-2003 04:20 AM
Question
Sorry, I did not see anything from the experts on the correct seal depth when installed for the updated seal:
Does the flywheel seal go in until it is just flush with the case?
I got the brown/black one with ribs on the outside, which I am told is the best updated part, and it went in fine with some effort until it is just flush with the case.
I am trying to be very careful not to deform it and just want to make sure it should not go any deeper before reassembly.
Thanks,
Olivier
surflvr911sc 12-23-2003 06:06 AM
There is room for it to go in further but flush w/ the case is good to go!
ohecht 12-23-2003 08:33 AM
Thanks, that makes me feel better. It seems that I have a question along these lines with every part I replace. I am enjoying all the access to these parts of the engine, but also worried I will make things worse by disturbing seals on what was at most a seepage issue that was still within oil "consumption" specs.
Thanks again,
Olivier
Superman 12-23-2003 08:39 AM
I understand all those emotions, Olivier. All that worrying just makes for a satisfying feeling when it's back together and works just great.
svandamme 12-23-2003 09:16 AM
you had beer pouring out of the bell housing? Is that a factory Heineken engine?
Heiniken is not a beer, it's pisswater... if any 911 had beer pouring out of it , i'de be proper beer, German, or in case of a Turbo , Belgian Duvel beer .
ohecht 12-23-2003 09:21 AM
Thanks, Superman. As much as I look forward to getting it back on the road as soon as possible, I am taking my time and enjoying all the exploration and ability to fix and clean things I cannot normally reach.
Olivier
KTL 12-23-2003 01:32 PM
Don't worry about pushing that crank seal in a little further. Doing so actually give the seal lip a "fresher" surface on which to ride. Over time, the seal can actually wear an ever-so-tiny/shallow groove in the crank flange.
