-   -   3.6 Install - It's Alive! (http://forums.pelicanparts.com/porsche-911-technical-forum/137670-3-6-install-its-alive.html)
surflvr911sc 12-04-2003 10:11 AM
Thanks Denis, from all the guys I've talked to, and I've talked to a lot including Tyson, they agree that the assembly lube was the likely culprit. I think that assembly lube gets even slicker when it mixes w/ oil.
The seal was just sitting there. I pushed on it and it just started to slip right back in, slippery little sucker. I probably could have pushed all the way in w/ just my fingers.
I’ll be using a little CurilT on the new one for insurance.
Doug Zielke 12-04-2003 06:37 PM
Originally posted by Leland Pate
Also, have we decided on a place for the '04 Roundup?
As soon as we know I'm putting in for leave!
The 2004 SCWDP Round-Up will be held in Canada this year (it's officially a 'Can-Am' event, so it's 'our' turn to host and organize in '04).
Venue for the event will be beautiful Penticton, BC. Those of you who have been there, will know what a great location this is.
I'm working on the details already. Originally, it was announced for the last weekend in July, however, the ALMS decided to return to Portland International Raceway in '04, on that weekend.
Because many of us here in the region, will want to attend the race, I will be moving the Round-Up to early August; probably the 2nd weekend in August. Stay tuned!
ischmitz 12-04-2003 07:26 PM
Ryan, that concerns me. There should be no way to get the seal started that easy with just yours fingers no matter how much lube and oil there is. Does yours still have the barbs on the outside or did it maybe spin in its seats and erroded them away. Anyway, you won't re-use it but hang it into your garage as a reminder of how such little things can cause so much extra work, right :)
Myself and everyone I have talked to had quite a ball getting the thing even started. I was in fact wondering if I had ended up with the wrong seal (too big). It should be a really tight fit that makes you nervous you bang the seal up when trying to put it in.
Ingo
surflvr911sc 12-04-2003 07:35 PM
Doug, I’ll watch out for the updates, thanks!
I had the seal on the door step when I got home today and I’ve already installed it. It was a lot different then the other one. The old one didn’t have the ribs on the outside and they didn’t get worn off, that’s how it was when I got it.
I put the new one in and couldn’t get in the last mm. I thought that since I got the 12mm one it was as far as it would go and I was screwed. I carefully pulled it out and took a couple measurements, there is plenty of room in there. So I tried again, this time w/ a little more motivation it went in all the way and is flush w/ the case.
I don’t know why they were so different, although the old one was the “correct” 11mm seal. All I care about at this point is that it was an easy fix considering. Now I just need to get it cleaned up and back in but that won’t be until maybe Sunday.
Thanks for all the advice!
Doug Zielke 12-04-2003 07:47 PM
Ryan...the seal I used on the recent overhaul was from a genuine Porsche gasket kit. It had the 'ribs' on the outside perimeter that you mention.
The 'Bomber liked the ribs....
surflvr911sc 12-07-2003 08:03 AM
Engine went in last night, will finish everything else tonight (stuck at work right now).
Wish me luck!
Joe Bob 12-07-2003 08:27 AM
Ingo just came by and got my jack....he's pulling his this morning.
BTW...good luck, crossing fingers....at least as well as can be while taping and mudding sheetrock.
surflvr911sc 12-07-2003 09:44 PM
I look forward to seeing the new P-car pad Mike.
The old seal was pushed right out of the case. It was still in there but the flywheel was the only thing actually holding it in. I’m sure that the oil was mostly coming out of the tab in the case (at the top) because that was the only part that the seal wasn’t sealing at least a little. The seal looked like brand new.
The new seal was very different then the old seal. I bought the 12mm seal, which is actually the seal for the earlier 911 and the later 993 engines, why I don’t know. It fit much tighter, even though the sealing areas are supposed to be the exact same dimensions. It was black w/ a little brown in it, the old seal was all black. I used a little CurilT on the outer edge and I felt much more confident about the fit, so far no leaks.
I also opened the restrictor up to 3/8” from 1/4". It was probably unnecessary but I figured it couldn’t hurt. I now have a slight rpm change when I remove the oil cap but it will still idle fine.
I didn’t get the original seal from PP and I’m not sure what the actual part number was so I can’t say for sure if it was the right one or not, but I assume it was the correct 964 seal.
I’ve only driven another 4 miles around the neighborhood but I will definitely be stretching it’s legs more throughout the week. HooWoo!
Jack Olsen 12-07-2003 09:46 PM
Congratulations, Ryan. Are you bringing that beast out for the Mulholland run on the 13th?
maxnine11 12-07-2003 09:51 PM
that's good news Ryan :) !
surflvr911sc 12-07-2003 09:53 PM
I wish! I promised a buddy, about two months ago, that I would help him move that day. Unless I "strain my back" between now and then, I'm out.
I wont be able to make it on Jan 21 either, damn! I talked to Tyson and will be looking into the dates for the Streets series. I’m ready to get out there.
Did I mention that I’m getting good at engine removal & installation? :)
surflvr911sc 12-07-2003 10:23 PM
Something funny…
When I took it for the first drive around the block tonight, it felt as if the clutch was slipping. I tried to give it more power and nothing.
Hmm, if the clutch was slipping the rmps would climb or something. I readjusted the clutch but it was right on, checked everything else I could think of and nothing.
The thought of laying into the gas and nothing happening kept jumping out at me. “Are you sure you were in first gear?” a little voice asked.
Nope, sure wasn’t. This thing is a dog when you start in third gear from a stop. Readjusted the coupler and amazingly I have power again, who knew?
Thomas Owen 12-08-2003 03:58 AM
Well, good news. Let's hear a report of what it was like to drive...
Vipergrün 12-08-2003 08:21 AM
Ryan, I believe the first POC STS series weekend is Jan 31/Feb 1. The first day is DE and the second is STS1. I plan on doing as much of the series as I can and getting my STS license so I can go on to other things :)
So, post some video of that bad boy running!
-B
Thomas Owen 12-08-2003 09:54 AM
Last post from Ryan at 12:23 a.m. I guess he went for a drive and hasn't come back yet...
surflvr911sc 12-08-2003 10:08 AM
LOL Thomas! I only have 8.? miles on her so far so it would be hard to give a good driving impression. I’m leaving work early today so I can go test her out.
In the short amount of driving I’ve done so far, WOW! The power is so strong and so smooth throughout the entire rpm range. It pulls at 3000 like my 3.0 did at 5500. I feel like I wont really know what it can do until I get it out on the track, it gets up and moves so fast that anything after third gear, or 6 seconds, which ever comes first, is just asking for trouble.
I look forward to feeling how it handles in the twisties. I won’t be able lay into the gas coming out of a turn as soon as I did w/ the 3.0. More to follow.
rcwaldo 12-08-2003 10:41 PM
sounds as thought your new rear main seal is Viton instead of regular rubber. Viton make a much better seal or o-ring for sealing in high temp areas
have fun!
surflvr911sc 12-08-2003 10:45 PM
Here is an update from tonight. Driving impressions
Kevin Stewart 12-09-2003 09:22 AM
Ryan I have only put a 150 miles on my 3.6 due to a knock in the motor, but it is very hard to be humble when you drive one, the guys that have been knocking this conversion dont have a clue just how nice they are, lets just hope the knock is only a rocker arm backed off, and its to cold here to work on it, Kevin
TargaRob 12-11-2003 05:40 PM
I'm glad to hear everything is working. Can't wait to see and hear it!
