Installing pertronix ignitor
I am trying to install a pertronix ignitor in my 73T(mfi).
The car has the stock Permatune CD box and bosch coil.
Doe anyone have experience with this upgrade?
How do I wire the ignitor to the Permatune box?
Do I need to upgrade the coil?
Anything else I should be aware of?
Thanks, in advance.
Old 11-30-2003, 02:01 PM
Chuck Moreland's Avatar
Red wire goes to ignition switch +12v. Should be available on your engine fuse panel, bottom fuse. Black wire goes where the points used to connect.
Be aware -
- Instructions on some ignitor models are incorrect and tell you to connect to the coil. That doesn't work for CDI
- Make sure you get the little wheel seated properly
Chuck Moreland - elephantracing.com - vonnen.com
Old 11-30-2003, 02:30 PM
RETIRED
Joe Bob's Avatar
Give it the float test first.....
2012 ML350 3.0 Turbo Diesel
Old 11-30-2003, 03:32 PM
Thanks Chuck. Worked like a charm.
Old 11-30-2003, 03:45 PM
