I would rather be driving
jpnovak's Avatar
Foam air filters: KN alternative?
I was searching for carb parts and came across these foam filters.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33550&item=2454782968
I know they are from the infamous MM but it is a very cost effective replacement to the KN systems which has been debated many times for its filtering effectiveness. I used to be into ATV's when I was younger and am familiar with the filtering abilities of properly oiled foam filters.
I looked up the True Foam company to see what type of tests they had done. there is some interesting info regarding flow rates both clean and dirt loaded. You don't see results with KN filters.
I also stumbled across some dyno comparisons between stock and these filters.
http://www.off-roadweb.com/tech/0306or_intake/
These may just be an alternative to the KN filters. Colors too.
Wayne can you get these?
Whatdyallthink?
Old 01-23-2004, 11:42 AM
Senior Member
Check out Piper Cross Filter. North American dist for them Rene Berube of Upsolute NA
rberube@upsolute.com (704) 588 0207
They have both panel or cone filters. Great product.
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 01-23-2004, 11:52 AM
jpnovak's Avatar
Definately RSR red. Sorry I missed that thread.
Old 01-23-2004, 12:01 PM
Double Trouble
targa911S's Avatar
I just e mailed them but they do not make them for MFI ..carbs only. Bummer.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 01-23-2004, 12:04 PM
jpnovak's Avatar
The carb tops should fit MFI. You have to mod a watershield cover or use the flat top. P-thomas and others have done it.
Old 01-23-2004, 12:08 PM
tobluforu's Avatar
Foam is the best. Piper Cross makes some of the best filters in the world.
Old 01-23-2004, 12:14 PM
Double Trouble
targa911S's Avatar
hmmmmm...that's a thought.
75 914 1.8
2010 Cayenne base
Old 01-23-2004, 12:15 PM
vash's Avatar
on motorcycles i had both the Uni (foam) and the K&N. i actually think the K&N is better. it is easier to clean, and dry. stuff like that. i cant tell you which breathes better .
poof! gone
Old 01-23-2004, 12:16 PM
Gee, I wish they hadn't claimed a 12 HP improvement over the baseline test figure. Sounds like something K&N would claim. Still, I'm in the camp of foam over gauze.
Here's the earlier thread:
Foam filter elements for watershields - any good?
Sherwood
Old 01-23-2004, 01:42 PM
Cool
that's good enough for me..
so does anyone have the bottom line on foam for watershields.
Or I'm gonna hate to be stuck with K&N.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-23-2004, 02:35 PM
These look like they should work with Watershields; same top configuration and size. Wanna give Roy a call?
Sherwood
Old 01-23-2004, 03:58 PM
Cool
Sherwood
I'm gonna make calls tomorrow.. thanks.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-23-2004, 04:09 PM
Licensed User
Shuie's Avatar
Has anyone ever used the ITG Megaflow filters?
Old 01-23-2004, 05:18 PM
Embs's Avatar
Perhaps the carb guys won't have problems, but I can tell you from experience that lightly oiled filters of any kind should NOT be used on any engine with a Hot Film MAF system. IMO, K&N filthtration systems are a waste of money.
Old 01-23-2004, 05:35 PM
