I would rather be driving
Foam air filters: KN alternative?
I was searching for carb parts and came across these foam filters.
I know they are from the infamous MM but it is a very cost effective replacement to the KN systems which has been debated many times for its filtering effectiveness. I used to be into ATV's when I was younger and am familiar with the filtering abilities of properly oiled foam filters. I looked up the True Foam company to see what type of tests they had done. there is some interesting info regarding flow rates both clean and dirt loaded. You don't see results with KN filters. I also stumbled across some dyno comparisons between stock and these filters. http://www.off-roadweb.com/tech/0306or_intake/ These may just be an alternative to the KN filters. Colors too. Wayne can you get these? Whatdyallthink?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Senior Member
Check out Piper Cross Filter. North American dist for them Rene Berube of Upsolute NA
rberube@upsolute.com (704) 588 0207 They have both panel or cone filters. Great product.
78 Euro 911sc Targa 03 Hayden SCWDP Last edited by osidak; 01-23-2004 at 01:08 PM.. |
Definately RSR red. Sorry I missed that thread.
Double Trouble
I just e mailed them but they do not make them for MFI ..carbs only. Bummer.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
The carb tops should fit MFI. You have to mod a watershield cover or use the flat top. P-thomas and others have done it.
Foam is the best. Piper Cross makes some of the best filters in the world.
72 911 Although it is done at the moment, it will never be finished. |
Double Trouble
hmmmmm...that's a thought.
on motorcycles i had both the Uni (foam) and the K&N. i actually think the K&N is better. it is easier to clean, and dry. stuff like that. i cant tell you which breathes better .
poof! gone |
Gee, I wish they hadn't claimed a 12 HP improvement over the baseline test figure. Sounds like something K&N would claim. Still, I'm in the camp of foam over gauze.
Here's the earlier thread: Foam filter elements for watershields - any good? Sherwood |
so does anyone have the bottom line on foam for watershields. Or I'm gonna hate to be stuck with K&N.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
These look like they should work with Watershields; same top configuration and size. Wanna give Roy a call?
Sherwood |
Licensed User
Has anyone ever used the ITG Megaflow filters?
Perhaps the carb guys won't have problems, but I can tell you from experience that lightly oiled filters of any kind should NOT be used on any engine with a Hot Film MAF system. IMO, K&N filthtration systems are a waste of money.
