Love the new wheel(s) gonna have to save up the pennies as they seem pretty expensive saw a nice black one with a bit of red on it i fancy (cant remember the make)
How do you find driving a lhd over here in the uk?
i almost bought one from formula fuchs.
88 targa gone but not forgotten.
91 c4 coupe
Old 06-16-2004, 04:46 AM
dickster's Avatar
no problem with lhd - unless you go to a drive through alone, then you got to be flexible
honestly its no bother at all. the cars a little cheaper and they can be better maintained from somewhere like germany - plus they were meant to be lhd
i nearly went to formula fuch to look at a cab - they get some nice cars (all imports) but not sure about their rep?
Rich
'86 coupe
"there you are"
Old 06-16-2004, 06:07 AM
The car i was interested in a slate grey carrera has been on there books for ages as well as a few others.....makes you wonder whats up with them.
I bought my 88 private-risky i know but the condition and history were a1.
91 c4 coupe
Old 06-16-2004, 09:40 AM
dickster's Avatar
i wouldnt worry about them having them on their books for months, they a specialist cars and they dont shift quckly (generally).
i bought through a dealer but that said i would buy privately.
Rich
'86 coupe
"there you are"
Old 06-16-2004, 10:13 AM
Shaun @ Tru6's Avatar
bump as great post, thanks! Put a new wheel on at lunch today. What a marvelous difference it makes!
Tru6 Restoration & Design
Old 12-14-2004, 01:55 PM
kilodawg's Avatar
Perfect timing!
It's actually my project for this weekend!
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 12-14-2004, 02:28 PM
19 years and 17k posts...
azasadny's Avatar
Rich,
Nice wheel, I have the same one. Thanks for documenting the steps for others to follow!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 12-14-2004, 04:26 PM
Might as well thrown mine into the mix
Notice how everything past 60mph is not visible
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 12-14-2004, 05:55 PM
azasadny's Avatar
Here's my Prototipo
I installed mine earlier this year....
Art Zasadny
www.ford.com
Old 12-14-2004, 06:31 PM
dickster's Avatar
looking good.
having used mine for a year now I'm very pleased with it.
Rich
'86 coupe
"there you are"
Old 12-15-2004, 05:06 AM
Weaver's Avatar
Dickster- nice write-up with pics no less! Just as a friend though, I would recommend applying Loctite to the six small metric countersunk bolts holding the wheel itself to the hub. I would use either purple or blue, but nothing stronger than that. I had MOMO Monte Carlo wheels on three different cars and at some point, usually while driving, the bolts would come loose. I must have tightened the bolts on my Corrado's MOMO wheel about six times in three years.
If you noticed, the metric countersunk bolts they supply with the hub kit are not really trust worthy in my opinion. They are not of a high grade, so the countersink angle might be alittle off than the contersink angle of the wheel. Also, the allen slot seams to be very shallow, even for the small diameter and thread pitch. There was no way I was able to torque these bolts without rounding out the slot, and I was using brand new bits. I torque bolts everyday, as small as 6-32 and 8-32, and I had trouble with this little bolt, although I do forget the value I used, it was about 8 eyears ago now. And that cheap little allen key they supply will probable last you three uses. Also the threads in the hub itself seem alittle on the "loose" side and the thread depth is quite shallow. But the MOMO hub adapter is still the best quality hub on the market, imho.
Anyway, I would rather see you take out and put a small dab of loctite on the bolts now, than trying to screw the bolts back in with your finger tip while doing 80mph down the highway.
Take care
Weaver
'88 911 Targa
'03 911 Turbo, X73 Susp.
'13 Panamera GTS
PCA member Central Indiana
Old 12-15-2004, 06:38 AM
dickster's Avatar
weaver, great advice, thanks.
Rich
'86 coupe
"there you are"
Old 12-15-2004, 09:21 AM
strother's Avatar
If I hadn't searched and found this thread, I would have been hornless forever. For future searchers, this post worked for the Momo Monte Carlo steering wheel in my 1982 SC. Momo's instructions got the wheel attached, but they didn't help at all with the extra wire and the horn wiring.
1982 Platinum Metallic 911SC
Old 05-28-2005, 04:13 PM
Recreational User
porschenut's Avatar
I noticed you have the pinstripe velour seats! I have them in my 928 (below) but I've never seen them in a 911. Very nice departure from the usual leather.
Old 05-28-2005, 05:26 PM
Brother's Avatar
Did you have to use the club to get the original wheel off? This is perfect timing. I'm thinking about doing this since my hi beam/turn signal switch burnt up right before my eyes. (literally)
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 05-28-2005, 06:49 PM
strother's Avatar
I didn't have to use the club on my original wheel, but it had been taken off within the past few months by my shop. I think getting it off for the first time in 20 years would require the club.
Old 05-29-2005, 05:48 AM
dennis in se pa's Avatar
This post helped me ALOT!. The Momo graphical instructions suck! I did not know about the turn signal thing and was confused about the horn wiring until I found this post. Thank You!
I would recommend not putting ones tools away until a test drive confirms the steering wheel is straight.
Old 07-05-2006, 05:57 PM
dickster's Avatar
I am pleased it has helped, and it is what makes these forums so great
Rich
'86 coupe
"there you are"
Old 07-06-2006, 02:35 AM
carson911s's Avatar
Does anyone know the size of the nut inside the steering column ?
I dont have a socket big enough and need to buy one ...
'77 911S (3.2 SS)
'81 928 (gone)
Old 10-22-2010, 03:22 PM
carson911s's Avatar
I have just found it's 27 mm.
'77 911S (3.2 SS)
'81 928 (gone)
Old 10-22-2010, 03:24 PM
