-   -   idiots guide to momo prototipo install in a carrera (http://forums.pelicanparts.com/porsche-911-technical-forum/138526-idiots-guide-momo-prototipo-install-carrera.html)
dickster 12-06-2003 12:38 AM
(start by centreing the wheels) remove old wheel. prise off horn pad, and remove nut.
http://forums.pelicanparts.com/uploads2/51070699821.jpg
you're left with this
http://forums.pelicanparts.com/uploads2/61070699847.jpg
remove horn ring/indicator (repeater) cancel from bottom of old wheel
http://forums.pelicanparts.com/uploads2/71070699919.jpg
dickster 12-06-2003 12:41 AM
new bits to go on
http://forums.pelicanparts.com/uploads2/81070699984.jpg
place the piece from the bottom of old wheel to bottom of new hub (3 screws supplied are a little small)
http://forums.pelicanparts.com/uploads2/91070700055.jpg
cut off old small spade connector (new fitting indicates larger size) i left part of the spade there for fixing into block connector
http://forums.pelicanparts.com/uploa...1070700110.jpg
dickster 12-06-2003 12:47 AM
fit new hub to column. line up repeater cancel plastic stub with repeater stalk, while keeping centre the top hole for the steering wheel - the repeater cancel was slightly off, but still works. torque hub nut to steering column (dont forget washer) to 50nm - dont have lbs to hand.
http://forums.pelicanparts.com/uploa...1070700380.jpg
fit wheel (note the ring (see pic of all the bits) fits between wheel and hub adaptor - has a spade connector that i didnt need, but it forms the mount and earth for the horn push - mount the ring so that its male spade is on the opposite side of the wheel to the one on the horn push otherwise they may foul each other)
http://forums.pelicanparts.com/uploa...1070700415.jpg
wiring and fittings for horn push
http://forums.pelicanparts.com/uploa...1070700450.jpg
dickster 12-06-2003 12:51 AM
connect wire for horn push with a block.
http://forums.pelicanparts.com/uploa...1070700521.jpg
fit horn push. carefully push into place and make sure clips are not binding/catching - i used a small screwdriver to very carefully push the earth wire clip in.
http://forums.pelicanparts.com/uploa...1070700613.jpg
thats it 45 mins work.
dickster 12-06-2003 12:58 AM
before
http://forums.pelicanparts.com/uploads2/41070700906.jpg
http://forums.pelicanparts.com/uploads2/21070701050.jpg
after
http://forums.pelicanparts.com/uploa...1070701072.jpg http://forums.pelicanparts.com/uploa...1070701123.jpg
dickster 12-06-2003 01:01 AM
couple more
http://forums.pelicanparts.com/uploa...1070701267.jpg http://forums.pelicanparts.com/uploa...1070701278.jpg
AirCooledExcellence 12-06-2003 01:18 AM
Nice job Rich!
Good looking wheel that, I think I'll stick one on my xmas list!
Cheers,
Tim.
JonT 12-06-2003 04:34 AM
Great job Rich--good writeup too. I put a Momo wheel on my car and its funny how such a simple job can turn into a mess (in my case anyway--I drove around without a horn and no blinker shutoff for a week...so thats what those extra parts are for).
dickster 12-06-2003 11:10 AM
cheers, i think it makes the cabin more "business" like.
john, i know what you mean, i cannot believe they dont provide instruction - still thats the reason for the thread.
actually, maybe it is for safety reasons that they dont........
AirCooledExcellence 04-27-2004 06:41 AM
Thanks for the guide Rich! Just put it to good use over my lunch break:
http://tim.scott7.users.btopenworld.com/MD014800600.jpg
Had to 'persuade' the hub to fit the steering wheel shaft a bit though! Did you have to as well?
Cheers,
Tim.
mikester 04-27-2004 06:51 AM
Cheers,
Tim.
The steering wheel is on the wrong side of your car.
SmileWavy
TMH 04-27-2004 07:39 AM
Rich,
Nice write-up. I have now been through this procedure a couple of times, and it gets easier each time. A couple more hints to go along with your article:
1) At the very beginning, remove the horn relay to better maintain the sanity of both you and your neighbors during the job.
2) Final step: Pry (or prise, if in the UK) the speedo out of the dash and rotate it such that "your" useful range of the dial is not underneath the (smaller) steering wheel rim.
Done and done!
Tom
Wil Ferch 04-27-2004 08:10 AM
Don't forget that some us prefer to (also) use the small spacer, besides the hub adaptor. It moves the wheel further back towards you, but (more importantly perhaps) it maintains the stock wheel's "eccentricity" ( by mounting the wheel higher, when in the straight-ahead position). This gives a bit more visual room for the instruments.
---Wil Ferch
Adam 04-27-2004 03:42 PM
Good write-up, Rich!
When I did mine (late at night at Matt Holcomb's place), when we installed the horn button, even with the ignition off, we woke up the neighbourhood with rampant "toot"-ing as it clipped into place. :)
It's amazing the transformation a good Momo makes. If I knew it was going to be as good as it is, I would have done it three years ago.
Matt Smith 04-27-2004 04:39 PM
Nice!
Coupla questions:
Who sells the Porsche badge for the horn button, and what were the really early (911R etc) boss's like? Did they still have the concertina plastic sheath over them, or were they (I suspect) solid?
Thanks!
4to8m8 04-27-2004 05:06 PM
Competition
Had to bang on mine a bit to to get it all the way down on the shaft. (Wait a minute, that didn't sound write!!)
http://forums.pelicanparts.com/uploa...1083110647.jpg
dickster 06-16-2004 01:21 AM
i'm a bit behind here!
so *edit* TIM, you finally got your wish - looks great. no banging required btw - must be an "SC" issue ;)
matt, the horn push are quite readily available at suppliers - can't remember where i got mine - i think it was the wheel supplier. i have seen them on ebay as well. if you get stuck let me know and i'll try and dig out the invoice.
now that i've been using the wheel i can say that although it is heavier to use i love it.
thanks guys.
AirCooledExcellence 06-16-2004 01:32 AM
Blimey a bit behind, you aint joking!
Still asleep as well apparently, the name's Tim not Chris!! ;)
Cheers,
Tim.
dickster 06-16-2004 01:40 AM
TIM!!!
sorry about that - i sold some wheels on ebay and a bloke called Chris just came to pick them up! Thats the only excuse i've got.
89911 06-16-2004 04:20 AM
It must be nice to see more of your instruments! Where did you hide the air bag, under the horn button?;) Nice Job.
