Going to the Dyno tomorrow - HP Predictions?
The break-in is complete but no tuning has been done yet. I'm still running stock timing advance of 30-degrees and stock fuel pressures. Idle CO has been set to 2.5%. Going tomorrow to get an idea of what the new engine can do and the all imporant a/f graph.
Any HP predictions? Specs: USA 82 SC 3.0 with JE 9.7:1 pistons Elgin SC330 cams timed at 2.0mm SSI's with Dansk Sport 2/1 Intake ports and runners enlarged to 36mm
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
"Break-in" period?
Trying to keep up with you in the front of the pack at the last fun run, I would have said that baby was already broken-in. I look forward to seeing the outcome tomorrow...have fun. No predictions, are any of the Dorki taking bets yet?
Travis 1977 911S |
Joe |
Joe,
With the SSI's and the higher CR pistons, the low end torque is much more pronounced now than in stock form. If all else stayed the same, I would agree that increasing the intake sizes may have this affect. BTW: the machinist who did the work recommended keeping the exhaust ports stock for added back pressure to help the low end.
CS - nice way to spend vaca
Just a WAG but I'll wager right around 200 at the rear wheels ??????? Please let us HP deprived members know the outcome
Doug '81 SC Coupe Last edited by Doug E; 12-09-2003 at 06:24 PM.. |
201 RWHP
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
bump
are you slow or is it too early in the day? i blame it on the time difference...
good luck.
I'll bid 202 hp Bob. I just watched the Price is Right.
Senior Member
185 RW torque.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Black and Blue
198 rwhp...
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Chuck,
Whose dyno? Engine or chassis? What do you have to compare to, did you dyno before the change? If nothing else, put fresh, high octane gas in it from a known source. Make sure you keep the engine at a reasionably constant temperature. Do you have head temp gague? If a chassis dyno, set your rear tire pressures and note what tires you have (brand, condition, circumfrence.) If all you did was raise the CR, you will be more sensitive to fuel octane. Even at only 9.7:1. Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
drag racing the short bus
195 at the wheels.
The Terror of Tiny Town |
I'd say 190-195 with a disguistingly flat torque curve.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
205 rear wheel hp. just cant see how a 3.2 liter can make, on 3 different cars we tested, 210, and a " gone through" 3.0 wont make at least that much.
Jeff's stock 911 3.0 made 172ish, and it was stock with a minor muffler change. Let us know! Mk
Mark Kibort speedGT #19 Porsche 928 eRACING Motorsports www.electricsupercharger.com www.928trackcars.com/kibort |
196 @ the wheels
Rear wheels? I'll say 180 ponies...maybe even less. There is still some drivetrain power loss, even with a 911
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Where is that wrench?
182!
If you had gotten some better, more aggresive cams i think we'd expect more, but the sc330 cams i believe are just marginally more "radical" than the stock cams.
179 rwhp
Thank you for your time, |
Ah yes, the anti christ to the CIS system.
