911 clock upgrade??
I picked up a clock from a 1991 964.I would like to replace the broken clock in my 1975 with it. I have figured out which pins to use to power the clock and the lights but have no idea how to set the clock to the correct time. Has anyone done this conversion and could you let me know how to set the clock. thanks for any help. Joe W
Joe W 75 911 Wide Body 87 944
Old 12-09-2003, 05:23 PM
kjb kjb is offline
kjb's Avatar
I think the 964 clock is set by pressing a button on the dash. It then proceeds to spin around at a high pace, and you release the button when you're at the correct time.
Keep playing with the pins. Shorting one might send the clock spinning.
/ J
'86 coupe
Old 12-09-2003, 05:28 PM
Moses's Avatar
push and twist?
maxnine11's Avatar
not sure why you would want a clock with a bunch of warning lights (that aren't hooked up to anything).....but hey.....it's not my call
here is the wiring diagram showing the adjustment switch:
max
max
Old 12-09-2003, 05:52 PM
Max- Thanks for the wiring diagram!!! Joe W
Old 12-09-2003, 06:21 PM
Send a message via AIM to fintstone
Sorta like switching out the old classic Rollex for one of those red, glow-in-the dark, comes in a cereal box , watches.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-09-2003, 07:10 PM
