Fan touching housing,
My 911SC (11-blade fan) very slightly touches the fan housing at the bottom left hand side (wear marks). While I was replacing the belt I noticed that the fan has a little radial play. What's the cause, and what's the cure?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-10-2003, 08:09 AM
Moses's Avatar
Your alternator bearings are shot. Replace them FAST. A little play becomes a lot of wiggle in a hurry. If the bearings are not fixed in time, the wobble will ruin the brushes in the alternator and you'll get to replace that, too! (Ask me how I know!)
Old 12-10-2003, 08:18 AM
dtw dtw is offline
GAFB
Two potential causes -
More common: Worn-out bearings in the alternator (replace alt). Due to the radial play you mentioned, sounds like your winner.
Less common: Cracked/deformed fan housing (caused by over-torquing housing strap; requires replacement of housing).
Several BMWs
Old 12-10-2003, 08:19 AM
s_wilwerding's Avatar
I had that problem. I first had the alternator bearings replaced, but that didn't solve it. So, I took a Dremel tool and removed a little of the housing where the fan was hitting. No more noise!
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 12-10-2003, 08:21 AM
It'll be legen-waitforit
stealthn's Avatar
The fan rides on the alternator shaft, it could be time for an R/R of the alternator. Check the bearings and have it all refurbished while it's out.
Cheers
Bob James
06 Cayman S - Money Penny
18 Macan GTS
KTL KTL is offline
Schleprock
KTL's Avatar
Another possibility is that the alt. is not seating squarely in the fan housing. This would explain the rubbing in only one location?
Just a guess here. If the alt. bearings were shot (which it seems like they are since there's some radial movement), would there be rubbing in more than one location? But since the belt is pulling the alt. in one direction all the time.......... maybe rubbing remains isolated to one place.
Just throwing some things out there to think about.
Whatever the case may be, a removal of the fan/alt./housing combo. is inevitable.
Kevin L
'86 Carrera "Larry"
Old 12-10-2003, 09:35 AM
I was planning on dropping the engine to clean and seal it, plus to do other tidying work in January. It seems this will now happen even sooner. Thanks.
Old 12-10-2003, 09:44 AM
