Recreational User
DarrylD's Avatar
Cockpit Air/Fuel Ratio Gauge???
I'm toying with the idea of adding a volt meter and air/fuel ratio gauge like this one to my car:
My car doesn't currently have an oxygen sensor but it does have the provision for one that is currently plugged on the cat-bypass tube. Here's my question?
Can you use a gauge like this if you don't have an oxygen sensor control computer? Can you direct wire it to an oxygen sensor?
Old 03-14-2005, 10:02 AM
304065's Avatar
Darryl,
Search here for "LM-1." All will be revealed.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-14-2005, 10:38 AM
Administrator
Jack Olsen's Avatar
If you do a search on wide band oxygen sensors, you'll find a lot of ideas, including some DIY-type solutions.
Old 03-14-2005, 10:52 AM
Wer bremst verliert
JohnJL's Avatar
Yes, you can. I did it with an Autometer LED gauge and just welded in a bung for the O2 sensor in the collector.
Opt for a heated unit, which will give more accurate results quicker. You may want 2 sensors, one for each side.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-14-2005, 10:55 AM
fireant911's Avatar
DarrylD,
That appears to be a Westach A/F ratio meter - I installed one in my car last year and found the resulting information to be very useful. It is not neccesary that you have a Lambda computer in order to install the gauge. Wiring the gauge up was easy (three wires). There seems to be quite a lot of interest, at least on this board, on using the wide-band meters versus the narrow-band meters; however, this particular meter worked very well for me.
Daryl G.
1981 911 SC - sold 06/29/12
Old 03-14-2005, 11:03 AM
MAGA
Tim Hancock's Avatar
I am not real sure if this helps, but could you just use a simple EGT setup? If so, it would be simple to install and it would not require a computer or anything like that. This would not read in the same scale, but it definitely would show differences in mixture.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 03-14-2005, 11:05 AM
The A/F ratio gauge shown is used with narrow band O2 sensors. You can connect the sensor directly to the gauge. As was suggested, use at least a 3-wire sensor - better response.
If you use two sensors (one sensor on each bank), you'll need a switch to choose/display what's happening on each bank.
That said, narrow band sensors won't be as accurate outside the ideal 14.7:1 A/F ratio. There's a monetary step-up to a more accurate wide band sensor system.
Sherwood
Old 03-14-2005, 11:39 AM
randywebb's Avatar
What would be a minimum cost to go with this?
Gauge + sensor?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-14-2005, 12:30 PM
