drag racing the short bus
dd74's Avatar
Most and least important dash gauges
IMO, the most important is the oil pressure gauge - not the tach, since by sound and feel of the engine one is able to roughly measure its RPM. Oil pressure is another matter: when that goes south, the engine isn't far behind.
The oil level gauge is least important, since the dipstick is generally regarded as more accurate.
Other opinions as to what the most and least important dash gauges are?
The Terror of Tiny Town
Old 12-12-2003, 11:06 AM
Bandwidth AbUser
Jim Richards's Avatar
I think the gas gauge is important, unless you like getting stranded.
The clock is worthless...peedo is too if you can do the rpm to speed conversion in your head.
Jim R.
Old 12-12-2003, 11:09 AM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Most important- Oil temp
Least important- Odometer
Least important Honorable mention- speedo
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 12-12-2003, 11:10 AM
dd74's Avatar
Agree about oil temp being important. I equate it with the tach. But I think it is still better to have oil pumping through the engine, regardless of it being an acceptable temperature or hot. That's why I rank pressure as first.
YMMV.
Old 12-12-2003, 11:19 AM
Oil Pressure -> Oil temp -> Oil level -> Tach -> Gas -> Speedo -> Odo -> clock
Old 12-12-2003, 11:20 AM
Re: Most and least important dash gauges
and least
alternator light most imp demanding immediate reaction
oil level is least imp
all the others are for routine monitoring
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-12-2003, 11:21 AM
Automotive Monomaniac
Emission's Avatar
Oil Pressure - Oil Temp - Tach - Oil Level - Gas Level - Speedo - Clock
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 12-12-2003, 11:39 AM
goat's Avatar
Oil temp Most important.
Oil level for me is the least important. Yet I watch the d-thing all the time!
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 12-12-2003, 11:41 AM
nostatic's Avatar
gas guage doesn't mean much to me. I reset the trip odo at each fill, and know that after I hit 200 miles, I should start thinking about filling up.
Old 12-12-2003, 12:16 PM
Virginia Rocks!
VaSteve's Avatar
What about this red light. I can't ever seem to get it to come on....
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 12-12-2003, 12:57 PM
Oh yeah- I keep an eagle-eye on that one. If that comes on you're in BIIIIIG trouble.
Old 12-12-2003, 01:42 PM
Team California
speeder's Avatar
Speedo is kind of important if you want to hang on to your driver's licence, tach is trivial w/ rev limiter and sound to rely on. These are pretty low-revving motors anyways, in the big scheme of motors out there.
Denis
Old 12-12-2003, 01:43 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
By far the most important is a working alt. Light. If it comes on PULL OVER NOW! you've lost your fan belt. Don't ask me how I know. Next is the pressure and temp guages IMHo
And a fanbelt breaking doesn't always include an audible noise.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-12-2003, 01:45 PM
Typical Fish's Avatar
What DOES that light mean? I borrowed a friend of mine's SC for the weekend and he has one...
Matt
Old 12-12-2003, 01:46 PM
Oil Pressure, alt light, oil temp, tach, voltmeter, gas gauge, speedo, oil level.
I'd say the oil level is the least important, mine is completely accurate, but since I am only a quart or two low when it stops registering it's not really a big deal.
The most important gauges are the gauges that tell you the health of the motor instantly when it is running, oil pressure, temp, and alt light/volts (I added a voltmeter), then things that you can use/control gas, tach, speedo.
Old 12-12-2003, 02:38 PM
Pat S's Avatar
Who needs a tach when you have a rev limiter
Most important Oil Pressure
Least Important Oil Level
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 12-12-2003, 02:46 PM
Larry Harris's Avatar
WHAT DOES THE OXS RED LIGHT DO!!!
2001 Turbo
Old 12-12-2003, 03:26 PM
The OXS light is somehow connected to the odo & lights up every 30000 miles which is the replacement interval for the O2 sensor. There is some procedure to reset the light. My o2 sensor is approaching 30 000 miles of service so I think I'll have a party when that crrrrraaaazy light does its wonderful thing
Old 12-12-2003, 03:31 PM
It's for the Oxygen Sensor.
Back in the 80's lots of cars had some sort of notification set for preset intervals that they thought you should go by to replace the O2 sensor. I am guessing that the OXS light is on one of those preset intervals, but i suppose it could also come on when the O2 sensor is returning no signal or a wildly out of range signal.
Old 12-12-2003, 03:34 PM
Virginia Rocks!
VaSteve's Avatar
It must be related to the ticking/clicking sound - how it knows to go off that is. I had an Altima and the "Check Engine" light went off (I think it's the modern day equivalent - if there was a real problem the engine usually stops ). So I'm out in the "country" and I freakin panicked. It ended up being a $10 labor item with $90 of labor.
Old 12-12-2003, 05:31 PM
