LinkBack Thread Tools Rating: Thread Rating: 11 votes, 4.82 average.
Push it towards the guys who think carbs are so great. When I see their stuff I am glad to have CIS. I would however be very interested in your kit!
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 02-25-2004, 02:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #141 (permalink)
tbitz's Avatar
Now for the 'beta' (pre-production) kits. The price for the 'beta' units will be $1375US + shipping. They should be ready for shipment in 2 weeks. I am waiting for some parts to come in to finish them.
These kits, will be targeted for the 3.0l engine. I'd like to sell these to folks that will be doing the conversion as soon as they get the kit. The reason is, I need some feedback on installation guide and how things fit together.
You need basic tools and be comfortable with working on your car to be able to do the conversion. For example if you think changing the oil is too hard or complicated, then maybe this kit is not for you.
I will provide my configuration which will get you running and make the car drivable, but there will be some fine tuning. Youl need a laptop (with a serial port) to do the fine tuning.
I think the conversion can be done in one weekend, but I am somewhat biased. Feedback from users should give a better estimate.
Those interested in the beta kits, please email me at info@bitzracing.com
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 02-25-2004, 02:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #142 (permalink)
Hey what did you use for the boot?
Old 02-25-2004, 02:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #143 (permalink)
Senior Member
Leland Pate's Avatar
Wow momma... look at all that space for an intercooler....
This would be awesome to setup something w/ rfng's turbo setup!
I'd be very very interested in beta testing one of these kits for you, but I don't have a laptop and have no knowledge of "mapping" anything. That is the only aspect of this that scares me away. Man, if you had "me" do a beta test for you, you know almost anyone could install this kit!
Bravo Tony!
Chief Architect and Mastermind,
SCWDP
Old 02-25-2004, 02:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #144 (permalink)
banjomike's Avatar
Damn that's a lots sexier looking engine compartment than your typical CIS (or DME 3.2 or 3.6)!! I'm very interested, but I can't believe I'd have time to do it to soon. Do you think the final release version will be more or less $$
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 02-25-2004, 04:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #145 (permalink)
tbitz's Avatar
Bravo Tony!
Leland,
Considering you re-built your engine yourself, I think you are more than qualified for the installation. You really need a laptop though. You can use a desktop, it is just going to be a pain to have to come home plug in the desktop make a change and then go for a drive.
People seem to fear the tuning. I've already got a working MAP for the 3.0l 911SC engine. The setup on my 1978 911SC will come pre-programmed. You should be able to start the car and driveaway. The variations in intake path and ports of the later 911SC will require the fine tuning.
Tony
Old 02-25-2004, 04:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #146 (permalink)
tbitz's Avatar
I got the boot from a junk yard. Can't remember what it came from, 90's lumina I think.
Tony
Old 02-25-2004, 04:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #147 (permalink)
tbitz's Avatar
Production units will be priced higher. I am spending a lot of time fabricating pieces which is not worth my time. I will get machine shops to make these parts, and will have to pass on the extra cost to the end user.
I think the price for the complete kit is a bargain if you compare it to a complete TEC II system with throttle bodies ($10K). The kits are not the same, but it gives you an idea what it would currently cost you to go the EFI route with a production kit.
Tony
Old 02-25-2004, 05:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #148 (permalink)
tbitz's Avatar
Just to be clear the kit assumes you will use your existing CIS airbox as is. Air will follow the same path as it does in CIS. If you want the same setup as pictured above you will need to hackup your airbox and get an airfilter and a 90 degree boot:
Here is a list of what is included in these beta kits.
1 MegaSquirt ECU
1 Main wiring harness (from MegaSquirt to engine bay)
1 Fuel injector wiring harness with mating connector
1 ¼” plastic loom for engine bay wiring dress up (15’)
6 CIS to EFI injector bung
6 High impedance fuel injectors
1 Fuel pressure regulator
2 Aluminium Fuel rail
4 Fuel rail mounting bracket
4 M6x40 bolt (for mounting fuel rails)
4 M6 Nut, flat washer, lock washer
2 Fitting: -6AN male flare to –6AN O-ring
2 Fitting: -6AN male flare to –6AN swivel O-ring, 90 degree elbow
4 Fitting: -6AN swivel female flare to ¼” barbed
1 Vacuum hose (7/64” ID) 12’ length
8 Fuel injection hose clamps for ¼” hose
1 Fuel injection fuel hose (¼” ID) 6’ long
1 3 wire heated oxygen sensor with mating connector
1 Weld on oxygen sensor bung
1 Air temperature sensor with mating connector
1 Engine temperature sensor mounted on 5/16” terminal ring
1 1/8” plastic male nipple for vacuum pickup on air box
1 ATO fuse holder with 20Amp fuse
1 ATO fuse holder with 5 Amp fuse
1 ATO fuse holder with 3 Amp fuse
15 Red butt connectors
3 Blue 5/16” stud terminal ring
1 Red #10 stud terminal ring
2 Red T-TAP connector with mating blade
1 Tool: butt crimper, wire cutter
1 ½” black Snap bushing
15 Tie Wraps
1 Roll of electrical black tape
1 Velcro pad
1 Straight through serial cable
Tony
Old 02-25-2004, 07:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #149 (permalink)
Senior Member
Now I'm getting even more curious.
I just have so many questions. I am going to start on page one and go through the entire thread.
I wonder how your system will work with later SC's with the lambada brain. Does it get completely removed?
Ok, I'm gonna start reading now.
SCWDP
Old 02-25-2004, 08:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #150 (permalink)
Senior Member
Tony, I do not and will not open a whole new can of worms here, but I was thinking ... would it/could it be beneficial to use the intake runners from a 3.2 Carrera???
I am so excited about this. My CIS system has been acting up lately, and I think with the right amount of persuasion, I coulde get the wife to go for something like this.
All I really have to say is "Honey, better gas mileage!"
SCWDP
Old 02-25-2004, 09:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #151 (permalink)
Senior Member
Never mind about the carrera runners. I was thinking it may work because of a pic I remember seeing on Mark Hargett's site of the beast. It looks like he did some serious fabrication there with the two manifolds and the throttle body.
SCWDP
Old 02-25-2004, 09:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #152 (permalink)
tbitz's Avatar
Leland,
The beauty of this system is you can use your existing CIS intake runners and airbox. No need to spend a fortune on carrera intakes.
Tony
Old 02-26-2004, 06:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #153 (permalink)
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Hmm.. From the looks of it for us NA guys you might want to look into a kit that includes TWM throttle bodies. The cost would be significantly higher(1500 for the t-bodies) but for those of us running wild cams it would be great since it would cost about as much as a set of PMO's.
Just a thought.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-26-2004, 06:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #154 (permalink)
rpiper's Avatar
Tony, incredible work. I have a 78SC w/Euro 9.8:1 p/cs, ssis and CIS. Looking for an upgrade. Have you dyno'd this setup vs CIS yet? And, could a cam hotter than 964 be used? Thanks!
Bob Piper
78 911SC "Bullseye" SOLD
00 540i
02 CBR 954RR
98, 00, 03 sons
Old 02-26-2004, 08:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #155 (permalink)
tbitz's Avatar
As mentioned earlier in the thread. There is a fellow running my Megasquirt modification for use without TPS and has the following cams:
- GT-2 evo cams 485intake lift 464ex. 112 lobe center 20 overlap.
He says it runs great.
I have not dyno'd the car yet and don't want to make wild claims that have no scientific data to back it up. There is definitely a gain in power. Also the engine revs much quicker than with CIS. I have tuned the car for power, but still manage to get 25mpg on the highway. I think this can be improved if your after fuel economy. I'm after more power
Tony
Old 02-26-2004, 10:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #156 (permalink)
banjomike's Avatar
how easy is it to switch programs? It'd be nice to have a performance map, and emissions test map, and a fuel efficiency map. It'd be even nicer if you could switch between them on the fly.
Mike
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
Old 02-26-2004, 11:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #157 (permalink)
tbitz's Avatar
It is very easy. No need to open up the ECU or change any chips. Just have a serial port connection from the laptop to the ECU and you download the new MAP. MAPS can be changed in 5 seconds as many times as you like.
Tony
Old 02-26-2004, 11:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #158 (permalink)
beepbeep's Avatar
Hehehe...die CIS die!!
Thank you for your time,
Old 02-26-2004, 11:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #159 (permalink)
Senior Member
Do you have to purchase the software seperately?
SCWDP
Old 02-26-2004, 01:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #160 (permalink)
