magilla's Avatar
Bilstein Question
I have the normal black Boge struts on the front of my SC. I was given a set of lightly used Bilstein's to swap in. I checked Bilstein's wb site to see if they were HD's or Sports. They are HD's ( P36-0114). These are listed as for '85- '89. What is the difference? Will they not fit?
Thanks!
'83 SC Coupe- Blk/Blk
'03 Daughter- 10fingers/10toes
Old 12-14-2003, 09:20 AM
I'm not sure what the difference is, but the change from part number P36-0112 happened 4/1985, so I would say that there is indeed a difference, and they probably won't work.
Old 12-14-2003, 09:24 AM
magilla's Avatar
Is it a physical size issue, or a valving issue?
Old 12-14-2003, 10:49 AM
greglepore's Avatar
I'd call them and find out-if you search on "revalving Bilstein" or something like that, you'll probably find contact info for their tech folks, IIRC.
If they're Bilsteins for Boge struts, I doubt there is a physical size difference, as the struts are the same. Probaby different valving to accomodate the diff weight etc of the Carrera.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 12-14-2003, 11:51 AM
magilla's Avatar
Any one else have any ideas? Otherwise, I will try to contact Bilstein.
Old 12-15-2003, 07:11 AM
85Gold's Avatar
In the Pelican Catalogue there is a change in March of 1985 for Bilstein shocks however for Koni the part number stays the same. I would assume (we all know what that means) that it is not a dimensional issue but possibly a valving issue and Bilstein would be the place to find out.
Peter
2005 GT3 Black SCCA Solo 2 SS
1999 M Coupe SCCA SM2
2001 Mazda Miata (Wife's Ride)
2005 F150 FX4 + Trailex
Old 12-15-2003, 08:15 AM
magilla's Avatar
Resolution (for future reference):
I called Bilstein, and they were very helpful. They said that physically, there was no difference. They suggested that it would be a little stiffer than the P36-0112, and that the retaining nut is different. The part number for the correct retaining nut is 440959. I suppose Pelican can get them (or has them).
So, these are usable, as long as I get the right retaining nuts.
Note: These are simply inserts for the OE Boge struts, not entirely new struts.
Old 12-15-2003, 09:55 AM
Luke Hudson's Avatar
Wink
struts is struts, is struts BOGE/BILSTEIN/KONI, they all fit all 911's from 69-89, as long as your replacing the whole front strut assembly that is.
Of course they may not fit your brake calipers but that's another story.......
Aubergine 1972 911 2.4E - Gone but not forgotton
HP2S #1185 - Ain't she purty
Resident @ www.ddk-online.com
Old 12-15-2003, 10:01 AM
The part number that he gave was for the frt inserts, I am mostly certain.
FWIW, when I got my P36-0114 for my '88 it came with two nuts, an inside and an outside.
Old 12-15-2003, 10:49 AM
