3.2 CAB's Avatar
Question How Much Does Your 911 Weigh?
Just trying to find out, because I am curious to know how they compare. What does the TARGA, CAB. COUPE, and SLANTNOSE versions weigh in at on an axle scale. Front and rear weights and total weight. Not really interested in a stripped out AX or track unit, but an everyday driver with the standard/optional equipement, A/C, P/W, P/L etc. I have seen some of the "published weights" and I was trying to see the actual difference in the various models and weights. Thanks.
Old 12-14-2003, 11:02 AM
PRO Motorsports
Tyson Schmidt's Avatar
My bone-stock '92 C2 weighs 3008# with 3/8ths tank of fuel, and the tool kit and spare tire all present.
That's with the engine undertray and the rear storage compartment removed(replaces the rear seats on later cab's)
The weight distribution is 39.5/60.5
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 12-14-2003, 11:16 AM
'75 911S with 930 engine (stripped interior, manual cloth seats, RS carpets and doorpanels, no AC, RSR front, no rear bumperettes)
2300 lbs
'88 Carrera Targa (full interior, stereo, etc. but no AC)
2770 lbs
Old 12-14-2003, 11:46 AM
Team California
speeder's Avatar
Funny you should ask. Just weighed it yesterday:
This is a mostly stock '82 SC coupe, U.S. model, with spare tire and jack removed, 31lb. batterey, 7/8" Fuchs, almost empty fuel tank, A/C compressor removed, and 60lbs. of magazines and misc. junk removed from car and trunk!
Now before anyone gets a mental picture of me as one of those freaks who lives in a car filled to the water line w/ old newspapers and has cats living on the dashboard, this did not look like a lot of stuff! I was saying to Tyson, "there isn't much in there. Maybe 10lbs."
"Wanna bet?"
I lost.
Denis
Old 12-14-2003, 12:55 PM
My car weighs 2950 with a 180 lbs driver and a 1/2 tank. 81SC
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 12-14-2003, 03:09 PM
Bill Verburg's Avatar
Slightly modified C3 2687# w/ a full tank, tools, spare tire etc.
Bill Verburg
Old 12-14-2003, 03:22 PM
Dennis,
Does that say 2572?
I can hardly see it on my screen
Old 12-14-2003, 03:37 PM
70 911T into 73 2.7RS replica - about 2100 lbs depending on event
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Team California
speeder's Avatar
Yes, mine was 2572 lbs. I would like to get it lighter, I think that another 100 lbs. could come off w/o ruining it as a street car, but unfortunately it would ruin it for POC competition of any kind, including time trialing. In fact, I have to replace the A/C and some other weight.
EDIT: I should not have said *competition of any kind*, just stock, improved or production classes.
Denis
Old 12-14-2003, 04:17 PM
IROC's Avatar
My '76 weighed 2350lbs with the 2.7 in it, but I would suspect I'm up around 2450 now with the 3.2.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 12-14-2003, 04:27 PM
JTO JTO is offline
My '75 911S with a full tank weighs 2350 pounds on the certifed truck scale at work. The only weight reduction I have done is replaced the factory seats with Recaro SRDs and hollow torsion bars (21/27), and I bet the SSIs are lighter than the stock exhaust. I also removed the air pump. I have not AC, no power anything.
Troy
Troy
Past: 1975 911S Silver Anniversary-rebuilt and sublime.
Past: 1988 Carrera-backdated with a 3.6 and all the goodies.
Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's)
Old 12-14-2003, 04:48 PM
2980 pounds.... 1983SC Targa. 200lb driver/ full tank gas/ full trunk.
Old 12-14-2003, 05:02 PM
Wow... How is it that only left and rear is weighed?
Just curious how corner weighting works.... Should we try equalize left and right to be spot on?
Sprint.
Old 12-14-2003, 05:15 PM
rs911t's Avatar
2250 lbs with half-a-tank of gas, harness truss, harnesses and Corbeau Forzas in lieu of the factory sport seats. Woo-hoo!
Greg
Old 12-14-2003, 05:22 PM
Sprint.
Old 12-14-2003, 07:11 PM
Air Medal or two
afterburn 549's Avatar
1975 -911s with fiberglass bumpers ,spare, full tank 2350
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 12-14-2003, 08:26 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
2390 lbs. - Acording to the local garbage dump scales.
Car has:
Fiberglass front & rear bumpers
Fiberglass Rockers
No AC or components
No Smog Pump gear
6's & 7's Fuchs
Stock Spare Tire
Half a tank of gas
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 12-14-2003, 09:00 PM
Team California
speeder's Avatar
Sprint.
If you push a button on the scale, it will also give you the individual weights of each of the 4 wheels. The screen that is displayed is the important one, and the "cross %" is the operative # w/ corner balancing.
Obviously if you have the rear weight %, you don't need the front, w/ left % you don't need right, etc..
Denis
Old 12-14-2003, 09:05 PM
B D B D is offline
B D's Avatar
'68w/2.0 + 215 pound driver + 1/2 tank - spare tire = 2492 pounds
68 911L
Old 12-14-2003, 09:33 PM
Opps... I have my foot in my mouth and it don't taste too good. Haha... Thanks for pointing out the obvious to me. I do miss a lot at times.
Sprint.
Old 12-15-2003, 08:05 AM
