Tire Fitment Gurus - spring plate clearance question -
So here's the deal - a buddy of mine is giving me a great deal on some Kinesis 17 inch wheels with Hoosiers. I would like to use these as track wheels only.
With the stock 930 28 mm rear spacers on I have maybe 3 mm from the inner spring plate bolt to the tire rubber. In the pictures I attached, the shaft of the wrench is 5mm. I have a 5 mm spacer I could add, which oddly enough then gives me about 10mm of clearance. The problem is that I then only get about 6 turns on the lugs (which does not seem to be enough). A 30 mm spacer would probably be about perfect I guess, but I am wondering if they are o.k. as is. I would prefer not to grind down the spring plate bolts.
Any advice is appreciated.
[img]
http://forums.pelicanparts.com/uploads2/rear21071604345.jpg[/img] [img]
http://forums.pelicanparts.com/uploads2/rear31071604372.jpg[/img]
Old 12-16-2003, 11:56 AM
CHILI's Avatar
Oh, I wouldn't grind anything! Esp those bolts. It's pretty easy to change the studs. I changed one without having to remove the hub. Just had to remove the rotor and the e-brake adjuster to get the room to fit the new one in from behind. Or, go to a 3 mm specer as you said. But, check how many turns you get before any A/X or Track ing.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 12-16-2003, 01:03 PM
Bill Verburg's Avatar
Here's mine
You don't need much of a gap.
Bill Verburg
Old 12-16-2003, 01:59 PM
Thanks Bill - I was hoping you would reply. Although hard to tell in the pictures, it looks like your upper bolt may be even closer than mine. I assume you have never had any rubbing there?
I was just out test driving the car with the new wheels and I did not hear or feel anything. I will do a little more spirited driving and then pull everything off and check for rub marks. I really want these wheels to work as my buddy is giving me a great deal and they look and feel great. Plus, they are about 20 pounds lighter than the stock hollow spoke 996TT wheels I run on the street.
Bill
Old 12-16-2003, 02:19 PM
Crotchety Old Bastard
RarlyL8's Avatar
The wheels I'm using are back-spaced as much as possible.
I ground off the pring plate bolts flush with the nuts.
Works perfectly with maybe 2mm to spare. Has never rubbed in years of use.
Old 12-16-2003, 06:03 PM
Well it is probably o.k. as it is then. The only rubbing I have found so far is a slight rubbing on the wiper washer fluid reservoir when the wheels are turned to the extreme left (I doubt I would ever turn the wheels that far left on the track). Still - maybe an excuse to remove that thing. I have the second 1 liter reservoir in the trunk, so I can just tap into that. Hmm - maybe then I will have room for a seond oil cooler in the driver's side front fender.
Bill
Old 12-16-2003, 08:23 PM
