Super Moderator
cstreit's Avatar
Bilstein strut inserts - Why dif. length threads?!
Gang,
I've come up with a set of Bilstein struts with raised spindles...
Strangely, one cartridge has a threaded portion (for mounting through the camber plate) that is about 0.6" long, the other has one that is about 1.1" long...
Does anyone know the difference between the two?
Thanks,
Chris Streit
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-16-2003, 01:09 PM
Series900's Avatar
poor quality control :>)
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 12-16-2003, 01:20 PM
Super Moderator
cstreit's Avatar
I'm thinking the are two differnt years, but I want the longer thread one, just don't know what this insert is...
DOes anyone have a front Bilstein shock insert that they might be able to measure the thread for me?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-16-2003, 01:25 PM
PRO Motorsports
Tyson Schmidt's Avatar
Remember those years where they raised the ride height, and installed the thick washer underneath the upper strut mount?
Well, the long one is from those years, and the short one is from the other years. Either will work, but you'll just have to get used to one side having more threads showing out the top of the strut.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 12-16-2003, 07:16 PM
Super Moderator
cstreit's Avatar
Tyson, As usual, YOU DA MAN. Thanks.
Were it just that, I'd be un-concerned, but the issue is I have a pair of front monoball camber plates that Chuck Moreland things are ERP style.. THe bushing through which these threaded areas go through is taller than other comparable setups... So the longer threaded one fits through, the shorter does not...
SO... I can either but a new strut cartridge or buy monoballs from Chuck (or similar)... Strut cartridge is probably cheaper, but Chuck's monoballs look nicer.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-16-2003, 08:17 PM
