Original Owner
tsuter's Avatar
930 3.0L and SSIs
Anyone installed SSIs on a 930 3.0L and fabricated or bot a two into one (turbo) pipe for the SSI heat exchanger/header outlets to turbo inlet?
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 12-20-2003, 04:26 PM
Dept store Quartermaster
lendaddy's Avatar
Good question. It would be a complicated crossoverpipe though as there is not much room under the pully anyway and thats where it would have to go. You could completely relocate the turbo I guess, but where? Also, this would be an even longer route for the exhaust gases to travel which means lower EGTs at the turbo which = slower moving gases = bad. hmmm
Cornpoppin' Pony Soldier
Old 12-20-2003, 04:32 PM
Original Owner
tsuter's Avatar
Why is it longer? The traditional cross over to the Y pipe goes all the way across as well rigt to left. Just at the back instead of the front.
tsuter
Thaaaats Right!!
Old 12-20-2003, 05:09 PM
lendaddy's Avatar
I guess you would have to measure. You may be correct.
Old 12-20-2003, 05:10 PM
Original Owner
tsuter's Avatar
It would look something like the white pipe in this picture.
http://forums.pelicanparts.com/uploads2/turbo2.711071116156.jpg
tsuter
Thaaaats Right!!
Old 12-20-2003, 05:17 PM
lendaddy's Avatar
ohhh that is cool. I like it. Hmmm
Old 12-20-2003, 05:21 PM
Original Owner
tsuter's Avatar
Want to install the GHL 3" or 4" twin outlet muffler and see the effect on turbo lag then possibly put in SSIs with a custom crossover to the turbo like in that picture. Muffler first though if I can get the flange dimensions/ bolt pattern. Mine are 76MM square and it seems the 930 are 70mm?
http://www.securehost.biz/Merchant2/merchant.mvc?Screen=PROD&Product_Code=930911-TMD3RT&Category_Code=P-930Turbo&Store_Code=MS
tsuter
Thaaaats Right!!
Old 12-21-2003, 10:36 AM
Crotchety Old Bastard
RarlyL8's Avatar
There is a picture in Bruce Anderson's book showing a 930 engine with backdated heat exchangers. This is considered an upgrade from the very restrictive smog pipes that come stock. Turbo lag would be reduced, stock N/A heat exchangers are shorter than the smog exhaust of the US 930. The Euro exhaust also has a long run from exhaust port to turbo.
Old 12-21-2003, 07:38 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Where is the wastegate on that system?
Marc
Old 12-21-2003, 08:14 PM
Original Owner
tsuter's Avatar
It goes in the same place - mounted on a little extension pipe off the cross over connecting the SSI outlets to the turbo.
But who has one??
Theory is nice but.....
tsuter
Thaaaats Right!!
Old 12-22-2003, 06:07 AM
RarlyL8's Avatar
The crossover pipe you are discribing is very similar, if not the same as, the aftermarket pipe used for 2.7 and 3.0L N/A turbo conversions in the 80's. Rajay and others made this unit. You should make your own so that everything goes where you need it to. The muffler, turbo and wastegate share the same space.
Old 12-22-2003, 10:37 AM
