single pulley worth it on 3.6 conversion?
I'm planning some of the last details on my 3.6 conversion, which leads me to the "single pulley" debate. I've read that it spins the alternator slightly slower, yielding a small gain in power. It's also lower rotating mass, which should help, as well. The 993 cup cars have single pulleys.
Nevertheless, is it worth it to do this mod? It's ~$129 for the part, and I'm told a few hours of labor. Words of wisdom are appreciated.
Rob Fusi 77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s | GTC Motorsports |
Opted for single pulley at alternator only. Cleans things up a bit too.
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
If you don't have a single pulley conversion and you lose a belt, YOU could be in big trouble because your engine could cook quick and the belt minder (if still there) is dead.
So Mike, how fast are you going when you hit the redline in 1st? Or does it happen so quick that you don't really know.....
You know....I knew someone had asked me that and by the time I checked, I had forgotten who it was. Thanks for reminding me. Hard to be exact but it was around 37 mph. Gearbox is G50 with 8:31 r and p. Why do you ask? Is yours much different?
Also, looking at your engine pic, is that the vacuum canister for the Vram mounted near the rear left bracket (presumably where the heater blower once lived)? Looks better than having it tie wrapped to the intake spider like mine. Any problems relocating and mounting it there? Not sure I understand your explanation about the single pulley setup being better for avoiding catastrophic engine damage in the event of a broken belt. Please explain. And, am I safe in assuming that the inside belt is 10mm x 776mm (need to get a spare)? Could have PM'd but thought others may be interested in your setup.
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! Last edited by Mike Feinstein; 12-19-2003 at 05:21 PM.. |
I did both on mine, its only money and the Porsche gift certificate took most of the sting away. I agree that for a t/p where the belt minder light isn't hooked up it's a nice safety measure.
Bill and Todd,
Looks like both of you have a clean looking spacer to replace the outer alternator pulley. Did you fab this, or is it available somewhere? Dr. Timmins used a couple of spacers on mine. Also, is that belt 10 x776mm?
Mine top and bottom are the factory 993RS parts.
I used Patrick Motorsports
I guess I'm way behind the curve here; looks like it's time to upgrade to a varioram engine!
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I was initially dissapointed with the Vram (I thought) then I looked down at the speedo, felt like I was going about 85 but instead I was going 140. Last edited by Embs; 12-20-2003 at 09:37 AM.. |
If you have a factory belt the size should be imprinted on it. I found that mine was a 10mm by 776mm and they also make a 10mm by 760mm.
One word.........torque.
