How do you remove the gauges on a '69 911 please
So the gauges on the '69 911 have the two retention bolts on the backside to hold them in, unlike later gauges that can simply be popped out.
So here's my stupid question: how do you get to the backside of these gauges to unscrew the *$&@%%*# retention bolts? I tried to approach from underneath the dash this morning and couldn't even see the backside of the gauges. What am I missing here? Thanks to all!
1997 993TT 1973 Carrera RS #1334 1970 911S sunroof coupe '99 MBZ E55 1999, 2001 & 2003 daughters! |
It's alot of blind reaching and stretching to get at them from under the hood. Total PITA. That's the way to do it though.
Gon fix it with me hammer
be a very slim figured and agile person
in other words ... loose that beerbelly !!!
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
For some of the guages, it helps to remove the ventelation and fan box which only takes a few minutes. It doesn't make reaching all of the guages easy, but it does make reaching some of them easier.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Navin Johnson
Like John mentioned, remove the blower, then try and remove the clock, once you have one gauge removed, you can access the rest from the front. Reach in through the clock get the speedo, reach in through the speedo get the tach....
Id say go for the clock first... it seems easier to remove than the fuel gauge....
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Thanks for the tips guys. This outta be fun!
Rob
l
Navin Johnson
LOL the factory makes it sound so easy!!
remove small knurled nuts Try and get you hands under the dash an on the small knurled nut... its a pita
l
