| Registered |
				Main Pulley Bolt Removal
			The engine is out of the car with the transmission attached.  I have tried to remove this nut with a 1/2 drive impact wrench without success.  Also tried a breaker bar with a strap wrench around the pulley - no good either. Any options other than removing the transmission and locking down the flywheel. Thanks,
				__________________ Walt 82SC 3.0 81SC 3.6 | ||
|  06-06-2017, 01:44 PM |
| Registered Join Date: Oct 2001 Location: San Carlos, CA US
			Which 1/2 inch drive impact gun and what was the air PSI ?
				__________________ Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 | ||
|  06-06-2017, 02:05 PM |
| Registered |
			Unfortunately it's electric.  My air compressor isn't large enough to handle an air wrench.
|  06-06-2017, 03:07 PM |
| Registered Join Date: Oct 2008 Location: Nash County, NC.
			Heat the bolt hot enough to melt the loctite, then hit it with impact. Bruce | ||
|  06-06-2017, 03:30 PM |
| Registered |
			Walt: Does your car have A/C ? Because if it does, that bolt is torqued at around 150 ft lbs. Good luck
				__________________ Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) | ||
|  06-06-2017, 03:38 PM |
| Member 911 Anonymous |
			Lock your flywheel and use a breaker bar
				__________________ '85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC | ||
|  06-06-2017, 08:33 PM |
			He was trying to not remove the transmission so ....  My trusty Ingersol Rand 1/2 impact wrench at 125 psi has never let me down. Short of that, I think remove the starter and jam something into the gear. Although, I don't think it works as well as removing the gear box. It is really not that hard.
|  06-07-2017, 06:13 AM |
| Registered Join Date: Feb 2006 Location: Ontario Canada
			put it in gear and lock a driveshaft flange ?
				__________________ 1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) | ||
|  06-07-2017, 06:26 AM |
| Registered Join Date: Apr 2008 Location: Houston TX
			Between the time of trying two different techniques, posting here and waiting for an answer, you could have pulled the tranny, locked the flywheel with a short wrench, cracked the bold loose and put the tranny back on... Just sayin... Since the tranny is still mounted, is the starter there as well? Put breaker bar on bolt, prop end of breaker bar against floor, bump starter with jumper cables to battery for 1 second.
				__________________ Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! | ||
|  06-07-2017, 06:50 AM |
				 | Quote:
 I had a very close call last week. Really very lucky.
|  06-07-2017, 07:36 AM |
				 | Quote:
|  06-07-2017, 08:40 AM |
| Registered |
			Got the head of the bolt cherry red and it broke loose.  I forget that heat is your friend. Thanks Bruce. Walt
|  06-07-2017, 11:58 AM |
