Go Speedracer, go!
SpeedracerIndy's Avatar
How much HP does the 911 cooling fan cost?
Just wondering if anyone knows how much HP it takes to power the cooling fan for the engine. I have seen VW flat fours that have adopted the 911 cooling fan design, and I always hear that it is not a good idea because it robs so much HP. What would the "added" Horse power be if you unhooked the cooling fan.
Also, on a similar subject, how long would it take to cook the engine if the fan belt broke?
1981 SC ROW Coupe
Old 01-10-2004, 02:13 PM
Mikkel
Guest
Posts: n/a
I remember reading it in Auto Motor & Sport, but I can't remember the figure I think it was 16, but as I said I can't really remember
Without the fan you still have the oil cooler in the front fender. I think it's not too dangerous to "crawl" home with a broken fan belt.
Old 01-10-2004, 02:28 PM
Mikkel
Guest
Posts: n/a
Hey just thought of something; how will our 911s sound without the air fan!? Scary.... It would be like drinking coffee without sugar in it
Old 01-10-2004, 02:31 PM
Mikkel,
I think you are wrong about running without a fan. I think the motor will overheat very quickly.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 01-10-2004, 02:33 PM
I think the motor would overheat pretty quickly without the fan. The motor would probably overheat faster at low speeds because of the lack of airflow. At higher speeds there will be more airflow, but you'll also be making more heat. Either way it would be really bad.
Old 01-10-2004, 02:37 PM
Chuck Moreland's Avatar
Definitey do not run the engine without a fan. You will quickly have a meltdown. You will do internal damage within minutes.
16 HP might be a reasonable estimate. A thread from awhile back showed a savings of 7hp peak just by running the fan at a slightly slower speed.
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-10-2004, 02:48 PM
Larry Harris's Avatar
Sugar in your coffee!! My God man.
2001 Turbo
Old 01-10-2004, 03:08 PM
Bill Verburg's Avatar
cooling fan thread
Bill Verburg
Old 01-10-2004, 03:30 PM
Jocke's Avatar
Send a message via ICQ to Jocke
Great thread.
Why does it take so much HP?
/Jocke
Jocke Andersson
Reach me on ICQ - 317860713
Porsche 930 -77 SOLD
Modified, one of a kind in Sweden.
Check out my car @: http://members.cardomain.com/jocke
Old 01-10-2004, 04:16 PM
alf alf is offline
alf's Avatar
Along the same lines, how many horses would i free up if i disconnect the belt to the AC Compressor?
Yes, the AC is still hooked up. Why? I do not know, used it twice in the last 12 months. Blows cold.
alf
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 01-10-2004, 04:23 PM
Go Speedracer, go!
alf
My father has an 88 with a/c. While changing the belts last winter, I took off the AC, and didn't put it back on until summer. I couldn't tell a difference at all. When the a/c is not on, the clutch is disengaged, and the pulley is spinning freely. I think the drag from that freely spinning pulley is very negligible. I think the main benefit would be a big weight reduction if you were to remove the entire a/c system.
1981 SC ROW Coupe
Old 01-10-2004, 05:05 PM
Cool
upper cylinders and heads operate on the edge of the envelope with the fan connected. Engine oil that can take the heat are an issue, unless oil coking doesn't matter.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-10-2004, 05:23 PM
Lorenfb's Avatar
Did someone mention HP without suggesting a chip?
This forum must be getting too uptight.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 01-10-2004, 06:05 PM
Cool
LOL
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-10-2004, 06:08 PM
I'm not sure on our 911's but on a Cummins diesel (855 cu.in.) with 350 HP and around 1200 ft lbs of torque the fan's rob about 30HP.
I know it not apples to apples but 16HP on a flat-six sounds reasonable with all the blades and a lot less torque.
I would also NOT run a 911 without that fan even a short distance.
The diesels fan hardly ever turn's on. It has 11 gallons of coolant and just about as much oil with a big oil cooler and a big Turbo
It just doesn't corner as good as my SC
Old 01-10-2004, 06:20 PM
Cool
Yep.. sure does.
The Air C # is scary
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-10-2004, 06:34 PM
Randy Webb's Avatar
The definitive stmt:
from Ludvigson, Excellence Was Expected, 1st ed.:
On the 1963 911, the cooling fan took only 4.7% of the 901's gross engine output - p. 402, Ch. 16
Old 01-10-2004, 07:22 PM
Cool
hey Loren..
did you catch my reply in the cup holder thread.. LOL
God, I'm excited!
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-10-2004, 08:37 PM
If you read through the thread I posted you would note that @ 6100rpm the 3.6 fan is moving 1010 liters of air /sec = 8.3hp
An HVAC engineer friend and I did the calculations and they are correct thats what it takes to move that much air. That fan is moving a lot of air.
Bill Verburg
Old 01-10-2004, 09:27 PM
Go Speedracer, go!
8.3hp isn't all that much though considering the amount of air that it's moving. Even with a cooling fan that is 10% more efficient, you would only be saving about 1hp.
1981 SC ROW Coupe
Old 01-10-2004, 09:33 PM
