c2 rower's Avatar
Porsche special tool 9243
Has anyone ever come across this bugger? It is used for checking the balance between the two rear torsion bars which supposedly influences the corner balance to a large degree (perhaps because the spring rates are higher in the rear. You disconnect the rear sway bar, jack the front up and put this under the front cross member and lower it down onto this thing which basically acts like a pivot. This enables the rear springs to reach equilibrium. You measure the left and right and adjust the spring plates. Thats how it was described in the Oct 94 Excellence tech notes. Anyways, does anyone have a picture of the tool; I want to make one. And if anyone has actually tried this procedure I'd be interested in knowing how it went.
Big Hooters and 911's will always be in style
Old 01-05-2004, 05:11 PM
diy83sc's Avatar
c2,
I just read the article (tech note). Based on the description, it sounds like a plate to extend the width of the cross-member with a thick pipe welded to it. The other piece could be a similar plate that sits inside the cavity of a floor jack with two vertical plates on each end drilled to allow a bolt to pass through each end and through the center of the pipe on the other piece. Like a hinge? I architect software better than I do tools Great find! I may build one myself.
Tony
Old 01-05-2004, 07:35 PM
Cool
I couldn't find the article
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-06-2004, 05:16 AM
Irrationally exuberant
ChrisBennet's Avatar
Doesn't everyone just use corner weighting scales instead?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-06-2004, 06:57 AM
It looks like that would be alot cheaper to fabricate than corner balance scales
Old 01-06-2004, 08:55 AM
diy83sc's Avatar
Yeah! I would think that if the rear is set by balance and the rake is correct and as well the a-arm angle, the front would not be off by too much.
Tony
Old 01-06-2004, 09:25 AM
greglepore's Avatar
Man, that looks like a great idea, but how do you ensure that the pivot is directly aligned under the center of the car?
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 01-06-2004, 09:32 AM
diy83sc's Avatar
The diagram/drawing in Excellence shows a dimple of some sort. You could also use the two drain holes of the crossmember to center...
Tony
Old 01-06-2004, 03:16 PM
c2 rower's Avatar
Thanks for the pictures and comments. Four scales of sufficient capacity would not be trivial. The intent is to come up with something a do it yourselfer could do to achieve resonable corner balance on a 911.
Old 01-07-2004, 10:49 AM
billwagnon's Avatar
But four bathroom scales, four 2x12s, and four short 2x4s would be.
Old 01-07-2004, 11:02 AM
greglepore's Avatar
How would the bathroom scales work? The car weighs over 2300 lbs, so that's more than 500lbs a corner. Am I missing something?
Greg Lepore
85 Targa
Old 01-07-2004, 12:17 PM
djmcmath's Avatar
To second Greg, many of us have cars that weigh nearly 3000lbs (wet). From an engineering standpoint, I won't feel good about stuffing a scale under a tire unless I'm pretty sure it can support more than half of the car's weight, ie 1500lbs. I've honestly been keeping my eyes open, and haven't yet found a bathroom scale that'll do me for 1500lbs. If you have a lead on these, please let me know!
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 01-07-2004, 12:20 PM
c2 rower's Avatar
You could set up lever arms to make the bathrooom scales but the tough part is all surfaces need to be on the same level.
Old 01-07-2004, 12:23 PM
billwagnon's Avatar
end of 2x12 goes on the scale
other end is suspended by short 2x4
car wheel goes in the middle of the 2x12, towards the 2x4. the closer to the 2x4, the less weight is on the scale
put the wheel in the same place on every 2x12 and you can determine the proportional weight imbalance
if you know the weight of the car, sum the scale readings to determine the reduction factor
on my car the reduced amount was from 140 to 195 lbs on each wheel
having said all that, corner balancing is still the proverbial b!tch
Old 01-07-2004, 12:24 PM
