drag racing the short bus
dd74's Avatar
I need a 6th gear...
So I'm driving home on the freeway, and I'm in my top gear (5th) at around 4,000 (80 mph). At this rate, torque and horsepower are fairly in the sweet spot of a stock 3.0 with a 7.31 r/p and 50-series tires. I can pretty much accelerate with an eye's blink.
Here's the sitch: I start wondering if I can adapt a 6th gear to my 915 box. Is that possible? Has anyone done such an adaptation? I'm not complaining about my set up - I love it, actually. I'm just wondering about the possibilities.
If so, I'd keep the gears as they are, while leaving 6th as a true cruise gear - i.e. nice and low.
What do you guys think?
The Terror of Tiny Town
Old 01-09-2004, 10:14 PM
Buy them, sell them
Adam's Avatar
I've heard that you can piggy-back an extra gear on 4-speed 915s, for just that reason, but I don't know if the 5-speed has any room left.
Pity they don't have a tail/propshaft, you could add a Laycock-style electric overdrive!
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 01-09-2004, 10:33 PM
Irrationally exuberant
ChrisBennet's Avatar
You already have a 6th gear - it's just in the wrong direction.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-09-2004, 10:57 PM
dd74's Avatar
-Chris
Nuyk! Nuyk! Nuyk!
Old 01-09-2004, 11:03 PM
dd74's Avatar
I suffer from one of those unfortunate scenarios where I lose phone numbers. Nonetheless, at one time, I once had the home phone of the daughter of the old man who created Hewland transmissions. Great woman, but then I didn't need a tranny then.
Wish I had her phone number now.
Old 01-09-2004, 11:07 PM
Super Moderator
cstreit's Avatar
I've heard that Helands were mainly for lower horsepower cars...
Why not just change out 5th gear for something taller?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-09-2004, 11:15 PM
sithot's Avatar
Two choices:
Go to a higher aspect ratio.
Get new gears for your box.
First choice is cheap, second is not. Figure on $5,000 for a nicely done "stacked" box or just buy an over-drive 5th for your car. Tons of choices which may or may not cost tons of money!
Good luck,
Tom
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 01-09-2004, 11:21 PM
dd74's Avatar
Hewland makes one box for 140 hp max single seat race cars. The rest look to be for GT, GTS, LMP, etc race cars.
According to their web site, they don't suggest their transmissions be used in street cars. Straight-cut gears and all, just aren't streetable, I guess.
I could swap out fifth, but because of my torque, fifth has become almost a power gear now, and at about 90-100 mph, it's got a lot of punch, probably attributed to my car's weight and the small tires. I indeed like that as do most who've driven my set up.
Someone in Excellence advertises modified 915 and G50 transmissions allowing for sixth gearing, but I just can't remember who.
I would go with Hewland, but the cheapest (and weakest) tranny they have is about $20K!
Old 01-09-2004, 11:27 PM
dd74's Avatar
Originally posted by sithot
Two choices:
Good luck,
Tom
Thanks for the suggestion, Tom. But I do want to avoid higher aspect ratios. I went lower specifically to guarantee my car's responsiveness within the powerband I'm most likely to drive in. I'm usually at 4,000 to 5,500 RPMs with my engine, and I think 50-series tires truly help that out.
As far as a 5th overdrive, 5th is already overdrive for the car. But the way the car is set up now, 5th no longer acts like an overdrive gear.
Old 01-09-2004, 11:34 PM
Bill Verburg's Avatar
993 6 spd can be installed w/ some ..ummm.. mods
or
QUAIFE MK1 & MK2 6 SPEED HEAVY
DUTY TRANSAXLE GEARBOX
• Mk 1 ‘H’ pattern, dog engagement or synchromesh
• Mk 2 sequential, dog engagement
• Straight cut or helical gears
• Maximum suggested 650/700bhp
• QUAIFE ATB differential included
• Range of bellhousings
• Choice of output flnages
• Hydraulic clutch release assembly
• Various ratio options
• Remote gear lever – various length operating cables
Mk 2 only:
• Faster, lighter gearchange
• Compact drum type sequential design with modular
gear arrangement
• Dog engagement only – with open face dogs
QUAIFE Mk1 & Mk2 6 speed transaxle dog engagement
‘H’ pattern gearbox QBE25GH
QUAIFE Mk1 6 speed transaxle synchromesh
‘H’ pattern gearbox QBE26GH
Optional gear lever
Gear lever and cable QMGLL
Additional cable QMGLC
Drive shaft
Bellhousings
BMW M5 / Lotus / Porsche
Optional digital gear position indicator QMLED
3.889
1st 2nd 3rd 4th 5th 6th
3.400 2.000 1.276 0.941 0.717 0.612 Helical
2.615 1.938 1.474 1.136 0.929 0.800 Straight
GEAR RATIOS (Base Set)
FINAL DRIVE RATIOS
QUAIFE COMPLETE GEARBOXES
Quaiffe UK
Bill Verburg
Old 01-10-2004, 04:56 AM
ruf-porsche's Avatar
Two choices:
Good luck,
Tom
Third choice buy a 996 with a six speed trans!
Old 01-10-2004, 07:18 AM
Make Bruins Great Again
Por_sha911's Avatar
I like your thinking. When in doubt, find an excuse to buy yet another P-car. Then, sit back with a cup of good coffee and admire your accomplishments in life.
Joe
Old 01-10-2004, 09:36 AM
PRO Motorsports
Tyson Schmidt's Avatar
Your only option is a taller 5th. But you already have the taller 29/21 5th gear in your '74 trans. (Versus the 29/22 of the earlier 915's) But if you could find the 5th gear from a 912E, it is taller still.
I used to think my 5th gear was too short, until I rebuilt my 2.4 to E/Solex spec and raised the rev limit to 7,100. Now it's just right!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-10-2004, 09:48 AM
dd74,
The straight cut gears are not the problem, many street cars have had staight cut gears, none recently I would guess, noise is pretty high. Mini, for one I can recall, Austin Healy etc.
Main problem in the Hewland transmissions you were looking at is the absence of synchronizers.
I spent about 4 months with an XT_915, with dog gear engagement, non synchronized, in my road car when we were doing some product development. Cool fun doing clutchless, close ratio, near full throttle upshifts. Makes a CIS 2.7 feel like 300 hp.
The noise and the inconvenience in traffic was woeful, once the R&D was over, it came straight back out.
It is possible to do a 6 speed 915 with sequential shifting, but again with dog gears intended for racing. We have a layout for this solution, but have not taken any steps to build a test unit.
Regards
Hayden
Old 01-10-2004, 09:49 AM
PRO Motorsports
Yeah, they are NOISY!
I've driven racecars with straight-cut gears, and the open exhaust seemed pleasant and calming by comparison.
Gotta love dog-engagement though! Who needs a clutch? Reminds me of my dirt bike days, shifting a dog-box.
2004 GT3
Old 01-10-2004, 09:58 AM
