Retired, finally
SiberianDVM's Avatar
another 84 Carrera will not start, help please
Yesterday I had my 1984 911 at Carolinas Motorsports Park for a DE, and it ran great for 2 sessions. Tried to start it for session 3 and it cranked well but would not start. Swapped out DME relay with a new one with no improvement. Pulled a spark plug wire, used a spark plug, then a screwdriver close to ground, no visible spark.
Checked voltage at coil: 12.5 volts
Checked coil fuse: good
Car just had new plugs, plug wires, coil, rotor, distributor cap installed 2 months ago.
So I winched her onto the trailer and came home. This morning I swapped out new silver Brazilian coil for old black German coil, still no spark. New coil passed continuity checks. Checked rotor, dist cap, coil to distributor wire, all OK.
I had Steve Wong install his chip in my DME about a year ago. After reading the other thread, I guess I should pull it out and look at it and maybe send it to him to be checked.
Reference and speed sensors? I'll have to order those. I have a CHT sensor that I have not yet installed as it looked like a PIA. Any other things I can check?
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 09-08-2013, 08:50 AM
RETIRED
Joe Bob's Avatar
Is the DME relay audibly clicking when turning on the ignition?
2012 ML350 3.0 Turbo Diesel
Old 09-08-2013, 08:51 AM
French Import
zippy_gg's Avatar
Can you re-install the stock chip in the DME if you still have it? This would rule out a failed SW chip.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 09-08-2013, 08:58 AM
Retired, finally
That's the one under the seat between the DME and the altitude sensor, right?
Yes. It is not terribly loud, but I can feel it vibrate when the ignition is turned on and off, and using a stethoscope I can hear a distinct PING.
Old 09-08-2013, 10:20 AM
Retired, finally
I can. May save that for later, see next post.
Old 09-08-2013, 10:21 AM
Retired, finally
Found the reference and speed sensor connections in the engine compartment and removed enough ducting to get to them and disconnect them. I did basic ohmage tests.
Speed sensor (DG): INFINITE on 1-2, 2-3, 1-3
Reference sensor (BG): 1064 ohms on 1-2, INFINITE on 2-3 and 1-3.
Since the engine won't start at all but ran fine on the track an hour before, this makes absolutely no sense to me.
Should I go ahead and order 2 sensors? I already have a new CHT sensor.
Old 09-08-2013, 10:25 AM
RETIRED
Joe Bob's Avatar
$200 for a DME computer.....
86 Carrera computer with performance chip
And read this....
reference sensor
Old 09-09-2013, 12:03 PM
scarceller's Avatar
Your ohm test shows:
Speed sensor is bad
Ref sensor is good
It's very common to have the sensor's windings go open circuit after heat and or vibration and cool down. Your track session simply caused the speed sensor to fail.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 09-09-2013, 12:46 PM
Infinite resistance on speed sensor is ... not good.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-09-2013, 02:05 PM
I have an 84. I came home after a drive. It ran great and I put it away. The next day it would not start. It was the reference sensor......
Old 09-09-2013, 02:47 PM
Retired, finally
Thanks everyone, esp scarceller. Your posts here and on Rennlist have been invaluable. 2 new sensors on order, hopefully will be here by Friday and I can spend the weekend skinning my knuckles. That is a PITA area in which to work.
Old 09-10-2013, 04:38 AM
JTL JTL is offline
JTL's Avatar
Arrow +1 Reference Sensors
This happened to me twice and both times it was a bad ref sensor.
Cheers, Jt
-84 911 targa
Old 09-10-2013, 10:59 AM
scarceller's Avatar
This pic helps understand howto remove these sensors:
Sal
1964 356SC (SOLD)
Old 09-10-2013, 12:14 PM
Retired, finally
Unfortunately, I had to remove the bracket in order to remove the sensors, as they were really stuck. So yesterday I retested the sensors, speed sensor is the bad one, and JB Welded a thin washer onto the bad one. Good one I will keep as a spare.
Also installed a new CHT sensor as the old one was a single wire and the plastic connector was broken. Still tested good, though.
Is there a torque setting for the bracket to bell housing bolts? Or use Loctite?
Old 09-11-2013, 04:44 AM
Retired, finally
Got 2 new sensors installed last night. She fired up on the first crank.
Thanks everyone.
Old 09-14-2013, 06:10 AM
