Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
break in oil?
Just thought of this one. If we get so far as to start the 3.0 on sunday, what oil should I use for the break in? Is the usual 20-50 too heavy?
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 01-16-2004, 04:39 PM
AFJuvat's Avatar
Nope, use normal 20W50
Run it for the first 1000 miles, then change the oil.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-16-2004, 05:47 PM
Otto's Avatar
Use 30 wt Non Detergent oil for the first 1000 miles. Then 20-50. Otto
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 01-16-2004, 06:41 PM
Stahlwerks.com
jhelgesen's Avatar
What about the first 20 minute run in?
John Helgesen
Old 01-16-2004, 08:09 PM
Cool
ditto
it's what I did.
it's became tighter than a crabs ass.. and that's water tight.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-16-2004, 08:20 PM
Slumlord
Porsche_monkey's Avatar
I agre with Otto. Thinner is better at first.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 01-17-2004, 04:57 AM
Randy Webb's Avatar
Ron, You know crabs don't have asses...
Old 01-17-2004, 12:49 PM
Automotive Monomaniac
Emission's Avatar
Should you also avoid exceeding a certain RPM? New cars typically "limit" RPM to less than 4000 for the first 1000-1500 miles for break-in.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 01-17-2004, 12:51 PM
rw7810's Avatar
you should reag this opinion on break in tecnique. He makes some good points:
http://www.mototuneusa.com/break_in_secrets.htm
Robert Williams
70' 911T
Old 01-17-2004, 01:17 PM
Gon fix it with me hammer
svandamme's Avatar
change the oil a couple of times in short succession when it's a full rebuild according to Waynes rebuilding book
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-17-2004, 01:56 PM
svandamme's Avatar
that link , doesn't make sense to me, it says just run the engine hard first thing after a rebuild... his opinions are based on getting the most HP from your engine, and although his method might work to get performance , i very much doubt that it will prolong longetivity...
Stijn Vandamme
Old 01-17-2004, 02:01 PM
Larry Harris's Avatar
Keep the rpm under 3500 for the first 500 miles or so. Try and flucuate the rpm between 2500 and 4500 for the next 1000 miles. Avoid city driving as much as possible during the initial break-in. Change the oil after 250 miles and again at 1500 miles.
2001 Turbo
Old 01-17-2004, 03:46 PM
Randy Webb's Avatar
It would be interesting to compare that guy's advice with what race engine builders do to break in an engine on a dyno.
Old 01-17-2004, 04:23 PM
Slumlord
The engine should be run hard to seat the rings immediately. That helps build horsepower, street or track.
84 Cab - sold!
Old 01-19-2004, 06:32 AM
svandamme's Avatar
then how about the metal that comes of the not broken engine parts, which are settling in their enviroment? what's the effect of that?
i can imagine that it's no good to run it hard when the engine parts are still loosing metal and that metal is floating around in the oil
it seems to me that there's more to an engine than piston rings?
Stijn Vandamme
Old 01-19-2004, 06:57 AM
Super Moderator
cstreit's Avatar
This can also depend on the rings.
Mahle rings are known to be harder to seat. I tried teh MotoTune method and it was "not hard enough" and my rings didn't seat even after 1000 miles.
Tore it down, re-ringed again, then beat the piss outta my 3.0L and THEN they seated in 30 minutes.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-19-2004, 07:46 AM
rw7810's Avatar
So how do you know when your rings have "seated" ??
Robert Williams
70' 911T
Old 01-19-2004, 08:06 AM
svandamme's Avatar
compression test
Stijn Vandamme
Old 01-19-2004, 08:12 AM
Senior Member
Superman's Avatar
Run it HARD. In fact, have the timing light and stuff hooked up at startup time, set ignition timing and mixture quickly, then roar up and down the street making as much pressure against the rings as possible without going over about 4000 rpm.
Non-detergent 30w oil, at first. You can get it at the airport. Aircraft mechanics use it for beak-in.
Mocha 1978 911SC. "Coco"
Old 01-19-2004, 08:33 AM
Slumlord
a) Thats why you change the oil often.
b) Yes there's more to it than rings seating, but unseated rings on glazed bores can not be fixed without a tear-down. Run it hard from the start.
Old 01-19-2004, 08:36 AM
