Stahlwerks.com
break in oil?
Just thought of this one. If we get so far as to start the 3.0 on sunday, what oil should I use for the break in? Is the usual 20-50 too heavy?
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Nope, use normal 20W50
Run it for the first 1000 miles, then change the oil. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Use 30 wt Non Detergent oil for the first 1000 miles. Then 20-50. Otto
Racing Porsche for over 30 years. http://www.OttosVenice.com Check out the Porsche Owners Club Track event Videos |
Stahlwerks.com
What about the first 20 minute run in?
it's what I did. it's became tighter than a crabs ass.. and that's water tight.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Slumlord
I agre with Otto. Thinner is better at first.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Ron, You know crabs don't have asses...
Automotive Monomaniac
Should you also avoid exceeding a certain RPM? New cars typically "limit" RPM to less than 4000 for the first 1000-1500 miles for break-in.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
you should reag this opinion on break in tecnique. He makes some good points:
http://www.mototuneusa.com/break_in_secrets.htm
Robert Williams 70' 911T |
Gon fix it with me hammer
change the oil a couple of times in short succession when it's a full rebuild according to Waynes rebuilding book
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Keep the rpm under 3500 for the first 500 miles or so. Try and flucuate the rpm between 2500 and 4500 for the next 1000 miles. Avoid city driving as much as possible during the initial break-in. Change the oil after 250 miles and again at 1500 miles.
2001 Turbo |
It would be interesting to compare that guy's advice with what race engine builders do to break in an engine on a dyno.
Slumlord
The engine should be run hard to seat the rings immediately. That helps build horsepower, street or track.
then how about the metal that comes of the not broken engine parts, which are settling in their enviroment? what's the effect of that?
i can imagine that it's no good to run it hard when the engine parts are still loosing metal and that metal is floating around in the oil it seems to me that there's more to an engine than piston rings?
Super Moderator
This can also depend on the rings.
Mahle rings are known to be harder to seat. I tried teh MotoTune method and it was "not hard enough" and my rings didn't seat even after 1000 miles. Tore it down, re-ringed again, then beat the piss outta my 3.0L and THEN they seated in 30 minutes.
So how do you know when your rings have "seated" ??
compression test
Senior Member
Run it HARD. In fact, have the timing light and stuff hooked up at startup time, set ignition timing and mixture quickly, then roar up and down the street making as much pressure against the rings as possible without going over about 4000 rpm.
Non-detergent 30w oil, at first. You can get it at the airport. Aircraft mechanics use it for beak-in.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Slumlord
b) Yes there's more to it than rings seating, but unseated rings on glazed bores can not be fixed without a tear-down. Run it hard from the start. |
