I have the Bosch 0231159002 Distributor, which I believe cam from a 1967 911 S. I have installed an MSD Box and a Crane Optical Trigger. I have installed a new cap and rotor. I am not getting power from the end of the rotor to the spark plug wires. I am getting power to the rotor from the coil. Is there something in the rotor that would cause me to lose power from the center of the rotor to the outside? Is there something besides the rev limiter on these, like a resistor? What is the black coated part between the center contact of the rotor to the outer contact?
Chris Bell Confused owner with more 911 questions than answers......and no one to ask in West Texas. 1971 Targa, 1981 911 SC Targa, 1995 993 Coupe 2008 Cayman |
Chris,
That 'S' distributor has a rev-limiter rotor with a resistor element incorporated ... that can crack or burnout, causing an 'open' condition as you describe! ps ... the answer was a LOT closer than you suspected!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Since you're so close, I wish you'd just get in your car and come fix this dern thing......... I have had it for 6 weeks and have not heard it start yet.
Glad to know there is someone close by.
