FenderGuy's Avatar
Will a PPI detect broken head studs?
Just wondering if a PPI will detect broken head studs and if there is a valve job needed?
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 01-22-2004, 08:41 PM
Formerly bb80sc
Vipergrün's Avatar
I'd have the mechanic pull the valve covers and check the studs. A compression check and/or leak down could reveal possible valve issues, but there are other things, such as carbon buildup, which could skew the results.
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 01-22-2004, 08:44 PM
Make Bruins Great Again
Por_sha911's Avatar
When I bought my car last year I talked with 5-6 different dealers or mechanics. MOST PPIs are visual only. If you want to know if you need a valve job or have head stud problems, you'll have to pay extra for a leakdown test. Ask what the PPI covers and what the cost is to have a leakdown done at the same time (IMO its well worth it).
Joe
Old 01-22-2004, 08:55 PM
dtw dtw is offline
GAFB
Just make sure to specify that you want compression and leakdown tests, and inspection of the head studs (requires removal of the valve covers). The going rate here is $150-175.
-dtw
Several BMWs
Old 01-22-2004, 09:01 PM
What?!?!
DonDavis's Avatar
I would ask a shop to provide a sort of "checklist" that you could expect to see. Or at least a breakdown of what they check and costs associated with the "extra" items you would want inspected.
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 01-22-2004, 10:41 PM
