justesen's Avatar
9ii flag mirror mounting
I've just purchased a passenger side flag mirror for my 1977 911S. The mirror came with gaskets but no hardware. Does anyone have, or can anyone tell me what I need to mount this mirror?
I also have the driver side mirror which I'd like to sell. It's electric with the wire harness. The harness was cut to get it out of the car evidently but it is a perfectly clean cut that would be easy to splice.
JJ
Old 01-24-2004, 05:28 AM
Hi J, There is a sliding hook that is pulled tight by a phillips screw. No way to mount it otherwise.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 01-24-2004, 05:34 AM
nice doggie
Hetmann's Avatar
JJ,
The hardware is on the mirror you got. When you tighten the allen-head bolt, there is a little hook like piece that slides. If you have the right mounting holes, it will grab right on and snug right up. Both sides work the same way.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 01-24-2004, 05:36 AM
justesen's Avatar
Thanks Jerry and Toolman! It's so simple I missed it.
JJ
I know you believe you understand what you think I said, but I am not sure you realize that what you heard is not what I meant!
Old 01-24-2004, 05:42 AM
Are you aware of Mirror placement and the plate that goes below the mirror base,..The pass Mirror is off set from the drivers >>>Frank
Old 01-24-2004, 08:15 AM
justesen's Avatar
Frank,
I have the template for mirror placement but I hadn't heard about the plate that goes beneath the mirror base. Any idea where I can get one?
Thanks,
Jay
Old 01-25-2004, 06:24 AM
I belive I got mine from the P dealer...pretty cheap...Where ddid you get your template,..Becuse I need 1 aswell....Thanks Frank
Old 01-25-2004, 04:45 PM
Originally posted by justesen
Frank,
Thanks,
Jay
Jay,
Part numbers for the plates are here:
How are flag mirrors mounted?
Old 01-25-2004, 05:20 PM
