Power Window Operation Without Power
So I'm in the process of disassembling my SC for paint and I got myself in a bind. The door frames and glass need to come out but the power is already disconnected from the car and window motors. Any way to get the windows up and down without reconnecting everything? I hate those damned connections on the power window switch.
1982 911SC |
Full Send Society
Jump the connections with a battery?
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Power and ground from your jumper battery to the two center wires that went to the switch from the motor. One way goes up, and other goes down.
Booo
Well I was hoping there was a disconnect for the motor but that's life. Thanks.
1982 911SC |
You can remove the motor from each side (3 screws) then you should be able to move the regulator and get the glass out.
This worked a treat, thanks. So long as I was mindful of the regulator not to pinch the cables and wires I was able to rotate the whole assembly to bring the window up and down enough to get the window frame out.
1982 911SC |
Great! Glad it worked. Now keep the Pelican thread on the window switch wiring as you are going to need that at some point. I just installed power windows in my 1973 911T and used that post to wire my switches. cheers, Greg
Oh I have a bunch of photos of the wiring for those plugs, I hate those damned plugs.
1982 911SC |
I got tired of the power window switch wiring decades ago. A pack of multicolor metallic Sharpies later, this seems like the easiest solution...
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
That's pretty clever, I like it.
1982 911SC |
Yes, I agree. Now what we need is someone to tell us how to convert from 5 pin window switches to the old style 4 pin switches with the chrome bezels. The chrome bezel switches look sharp in a back-date or older 911.
Love this idea. Thanks !!
1988 911 Coupe Granite Green "Frogger" 1966 912R Coupe Stone Grey outlaw -"'Tilda" 1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter" 1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio) 1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001 |
Older thread but glad I caught this...have 1000 photos of different repairs and this takes some of that out of the equation.
1986 911 Coupe 1986 911 Targa |
I'm glad Pelican's are finding my tip helpful.
Ironically enough, I've since converted to manual windows on the '89 from the above photos.
Great idea. Sometimes the simplest solution is the best.
