From what I have read, if I simply buy a set of SSI's designed for a 1969 911T engine, they will simply bolt onto my newer 1975 2.7'S' engine?
I have no emission requirements and want a set of SSI's. What should I order?
-Rickeolis- 1986 Corvette |
you need to look into the oil line differences. i think wayne covers the details in his web site.
poof! gone |
Yeah, the P. Parts website claims 1978- on, for oil line differences, thanks-
Copied from Pelican: "Oil Line Update: It is important to note that all cars with cross-over exhaust systems (all 1978-89 911SC and Carrera) require the replacement of two oil lines with two older-style ones when installing the SSI heat exchangers (or any 1974 and earlier exhaust). These lines are part numbers C-107-728-00 (cars with a front-mounted cooler) and C-107-729-10 (no front-mounted cooler) and C-107-739-10 and are available for purchase below."
oh good! i was going to look, but i saw my boss coming so i had to minimize and punch up a graph or something. haha
poof! gone |
Rickeolis,
I put SSI's on my '77 which would be the same engine as your car and I think I remember that you can only use back as far as '74. The '73 and earlier take a different set. What I would do is contact SSI yourself and ask. They are a pretty good bunch of guys if you are asking about their products. Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
Glad I asked! I'll contact them and have them let me know about it, thanks!
Author of "101 Projects"
Here's the info:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_911REC_pg1.htm#item -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Got it, thanks Wayne.
The first two models cover almost all the years without the needs for emissions, now I see it. I'm building my order list-
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks Ronin, that's exactly why I ran this post. I'm hoping for input from those that have done this to a 2.7-
Anyone??
Hey rickeolis,
Here's what you'll need: ssi's with the thin flange - you have shorter studs than the later engines oil line kit to re-locate oil line (if you have external cooler) two - in muffler gaskets new copper hex nuts new allen nuts oil line wrench or large adjustable a 13mm(I think) socket w/ universal joint adapter one 13mm offset wrench one allen wrench - long to fit through access tunnels in exchangers WD-40 or similar to soak studs gunk or latex gloves patience band-aids that's all I can think of. The conversion is well worth it. Have fun.
Chris '75 911s 3.2 - Ice Green Metallic ‘87 951, '05 987 S '21 Jeep Gladiator ‘18 Tesla ModelX 100D, ‘20 Model 3 Last edited by catuck; 01-27-2004 at 07:40 PM.. |
my 2.7 had the long studs so I needed the thick flange SC SSI.. no problem.. I ordered a plug and gasket for the O2 bung from SSI. Eventually I'll use the bung to hook up a smog maching for a$$ hole SUVs that tailgate, on purpose to break my balls.. when I'm in the right lane in dangerous territory. So don't be discouraged if you need thick flanges.
So, I see that some 2.7's have thick flanges, and some thin?
I have '74 SSIs on my car. You can come by and look if you like. They were on my 2.7, but switched them to my new 3.0.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Chris '75 911s 3.2 - Ice Green Metallic ‘87 951, '05 987 S '21 Jeep Gladiator ‘18 Tesla ModelX 100D, ‘20 Model 3 |
Here are the parts you need:
911 211 021 60 Heat Exchanger Left Side Stainless Steel Carbureted and CIS 911 211 022 10 Heat Exchanger Right Side Stainless Steel 900 075 148 02 Bolts 10 x 32 (4) 999 084 002 02 Hex Nuts (4) 901 111 193 00 Gaskets (2) 900 028 008 02 Washers (2) 900 076 010 02 Hex Nuts (2) 901 111 195 00 Gasket (6) 900 076 025 02 Hex Nut (6) 999 085 001 02 Barrel Nuts (6) 901 211 193 00 Hearter Hose 901 211 194 02 Heater Hose 999 512 128 02 Clamp (4) 911 111 025 01 Muffler 901 111 151 04 Bracket 901 111 157 04 Clamp (2) 900 067 078 02 Bolt (2) 900 025 00702 Washer (2) 900 028 024 02 Washer (2) 900 076 025 hex nut (20) 911 107 739 10 Oil Line Engine (Pump) to Tank or Regulator 911 107 743 10 Front Oil Cooler Engine Pipe to Regulator Otto
Racing Porsche for over 30 years. http://www.OttosVenice.com Check out the Porsche Owners Club Track event Videos |
Thanks guys, I am going to go ahead and order the thin flange style today from Wayne and the boys.
Fintstone, I would love to see your car soon, I'll send you an e-mail. Otto, nice web site! I hope I don't need everything on that list though, but we'll see, thanks. I have an original early 2-in-1-out muffler, but I want to try one of those Stinger style setups to help save weight and increase flow.
