-   -   Can I Delete This? (http://forums.pelicanparts.com/porsche-911-technical-forum/146356-can-i-delete.html)
Schrup 01-30-2004 09:11 AM
Can I Delete This?
I will soon be smogging my car for the last time. After which I am going to install some SSIs & delete as much smog crap as I can till I can ditch the CIS. I am also installing a carpet kit & wonder if after the smog test if I'll be able to get rid of the box (not sure the name of it) under the passenger seat. My motor is the stock 80 3 liter. Here is a pic.
http://forums.pelicanparts.com/uploa...1075482652.jpg
ubiquity0 01-30-2004 09:16 AM
I know that if I unplug this in my car, it runs like cr*p.
Eric Mckenna 01-30-2004 09:18 AM
Paul,
Remove all that black tar from your tubs floor..
That crap is dead weight..
You'll thank me later .. hahaha .... maybe..
it's a messy job..
Eric
Schrup 01-30-2004 09:18 AM
What year is your car? I was told that in a 1980 it's not as intergrated.
Eric Mckenna 01-30-2004 09:19 AM
I have a 78 Tub with a 82 motor.. and I do not have that box.. huh.. oh well looks like dead weight anyhow! hahaha
Wayne 962 01-30-2004 09:24 AM
Not recommended.
-Wayne
mjshira 01-30-2004 10:14 AM
in a word, no.
RickM 01-30-2004 10:17 AM
What is it?
alf 01-30-2004 10:20 AM
That is where you put Steve Wong's chip :)
surflvr911sc 01-30-2004 10:21 AM
That's the Lambada(sp) brain, it runs the frequency valve for the '80-'83 CIS. I'm not sure exactly what the frequency valve does w/ out it but I know it's not good (runs like crap).
Once you go to carbs you can ditch it of course.
And no, Steve's chip wont do anything for that.
emcon5 01-30-2004 10:23 AM
That is the control box for the Lamda system.
On CIS-Lamda cars, fuel mixture is adjusted by controlling the duty cycle of the frequency valve. The Freq valve is essentially an EFI injector, on a fuel line going to the bottom chamber of the fuel distributor. It takes a rich/lean signal from the O2 sensor and adjusts the duty cycle up and down to compensate.
With no signal from the O2 sensor, the freq valve defaults to a slightly rich condition, but the freq valve is still operating. Without the control box (or the power relay next to it) it will not run, and you car will run really badly, if at all.
Tom
Pete000 01-30-2004 10:26 AM
With its brain it sure would not run to well....
JohnnieA 01-30-2004 12:43 PM
datz where ya hidez da jointz
konish 01-30-2004 01:16 PM
I believe that "Lambada" is the forbidden dance...merely performing it may be illegal in this country...come on its Friday...;-)
R/
Dustin
Hetmann 01-30-2004 03:32 PM
In my car that's where the amplifier sits. Perhaps you could find out how a 78 controls its Lambada frequencies....
Por_sha911 01-30-2004 04:43 PM
If you attached an e-ram and a cool-collar to the box you can get 25% more horsepower and run 10 degrees cooler http://www.pelicanparts.com/support/smileys/128.gif
trj911 01-30-2004 04:56 PM
I've been messing with my interior over the past month and I was wondering the same thing about that box. Now I know. Paul, thanks for asking.
Scooter 01-30-2004 04:58 PM
No chip in an SC, but good try!
kstar 01-30-2004 06:39 PM
Whatever you do, do not open that box!
BR,
Kurt
john70t 01-30-2004 07:03 PM
pandora effect
