Binge User
Can I Delete This?
I will soon be smogging my car for the last time. After which I am going to install some SSIs & delete as much smog crap as I can till I can ditch the CIS. I am also installing a carpet kit & wonder if after the smog test if I'll be able to get rid of the box (not sure the name of it) under the passenger seat. My motor is the stock 80 3 liter. Here is a pic.
Paul |
I know that if I unplug this in my car, it runs like cr*p.
Paul,
Remove all that black tar from your tubs floor.. That crap is dead weight.. You'll thank me later .. hahaha .... maybe.. it's a messy job.. Eric
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
Binge User
What year is your car? I was told that in a 1980 it's not as intergrated.
Paul |
I have a 78 Tub with a 82 motor.. and I do not have that box.. huh.. oh well looks like dead weight anyhow! hahaha
Author of "101 Projects"
Not recommended.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Sports Purpose 911 Driver
in a word, no.
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
What is it?
Warren & Ron, may you rest in Peace. |
That is where you put Steve Wong's chip
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
SCWDP- Shock and Awe Dept
That's the Lambada(sp) brain, it runs the frequency valve for the '80-'83 CIS. I'm not sure exactly what the frequency valve does w/ out it but I know it's not good (runs like crap).
Once you go to carbs you can ditch it of course. And no, Steve's chip wont do anything for that.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Hilbilly Deluxe
That is the control box for the Lamda system.
On CIS-Lamda cars, fuel mixture is adjusted by controlling the duty cycle of the frequency valve. The Freq valve is essentially an EFI injector, on a fuel line going to the bottom chamber of the fuel distributor. It takes a rich/lean signal from the O2 sensor and adjusts the duty cycle up and down to compensate. With no signal from the O2 sensor, the freq valve defaults to a slightly rich condition, but the freq valve is still operating. Without the control box (or the power relay next to it) it will not run, and you car will run really badly, if at all. Tom |
With its brain it sure would not run to well....
Work to Live, don't live to work... |
datz where ya hidez da jointz
John 1988 930 Last edited by JohnnieA; 01-31-2004 at 06:56 AM.. |
I believe that "Lambada" is the forbidden dance...merely performing it may be illegal in this country...come on its Friday...;-)
R/ Dustin |
nice doggie
In my car that's where the amplifier sits. Perhaps you could find out how a 78 controls its Lambada frequencies....
Jerry 78 SC hotrod 02 Mini Cooper S |
Make Bruins Great Again
If you attached an e-ram and a cool-collar to the box you can get 25% more horsepower and run 10 degrees cooler
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
What?
I've been messing with my interior over the past month and I was wondering the same thing about that box. Now I know. Paul, thanks for asking.
Tom J. 911SC Cab SCWDP CaymanS |
Bye, Bye.
Elvis has left the building. |
Monkey with a mouse
Whatever you do, do not open that box!
BR, Kurt |
You do not have permissi
pandora effect
Meanwhile other things are still happening. |
