What size is the big nut that holds the steering wheel on? It was 24mm on my 944 but the 911 nut is much bigger. We all knew that the 911 has bigger nuts though, didn't we...
1979 911SC "Frankencab" Dave |
The nut on my '87 is 27mm
Matthew D. '87 Carrera Coupe Guards Red/Cold A/C PCA Member |
27mm
Havin a little trouble gettin your nut on?
sorry.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Eric... What took you so long?
Well thank you, thank you very much!
I just took my apart. i used a 28 mm socket to take it off.
truly, Phil. 911 74 targa. |
28?!? 27? Man, now I need to buy 2 sockets! Sigh...
The nut that holds my wheel is about 2 meters.
'83 SC Coupe- Blk/Blk '03 Daughter- 10fingers/10toes |
