Binge User
Schrup's Avatar
Can I Delete This?
I will soon be smogging my car for the last time. After which I am going to install some SSIs & delete as much smog crap as I can till I can ditch the CIS. I am also installing a carpet kit & wonder if after the smog test if I'll be able to get rid of the box (not sure the name of it) under the passenger seat. My motor is the stock 80 3 liter. Here is a pic.
Paul
Old 01-30-2004, 09:11 AM
I know that if I unplug this in my car, it runs like cr*p.
Old 01-30-2004, 09:16 AM
Eric Mckenna's Avatar
Paul,
Remove all that black tar from your tubs floor..
That crap is dead weight..
You'll thank me later .. hahaha .... maybe..
it's a messy job..
Eric
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 01-30-2004, 09:18 AM
Binge User
Schrup's Avatar
What year is your car? I was told that in a 1980 it's not as intergrated.
Paul
I have a 78 Tub with a 82 motor.. and I do not have that box.. huh.. oh well looks like dead weight anyhow! hahaha
Famous last words..
Old 01-30-2004, 09:19 AM
Sports Purpose 911 Driver
mjshira's Avatar
in a word, no.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 01-30-2004, 10:14 AM
What is it?
Warren & Ron, may you rest in Peace.
Old 01-30-2004, 10:17 AM
alf alf is offline
alf's Avatar
That is where you put Steve Wong's chip
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 01-30-2004, 10:20 AM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
That's the Lambada(sp) brain, it runs the frequency valve for the '80-'83 CIS. I'm not sure exactly what the frequency valve does w/ out it but I know it's not good (runs like crap).
Once you go to carbs you can ditch it of course.
And no, Steve's chip wont do anything for that.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 01-30-2004, 10:21 AM
Hilbilly Deluxe
emcon5's Avatar
That is the control box for the Lamda system.
On CIS-Lamda cars, fuel mixture is adjusted by controlling the duty cycle of the frequency valve. The Freq valve is essentially an EFI injector, on a fuel line going to the bottom chamber of the fuel distributor. It takes a rich/lean signal from the O2 sensor and adjusts the duty cycle up and down to compensate.
With no signal from the O2 sensor, the freq valve defaults to a slightly rich condition, but the freq valve is still operating. Without the control box (or the power relay next to it) it will not run, and you car will run really badly, if at all.
Tom
82 911SC Coupe
GTI Cup #43
Old 01-30-2004, 10:23 AM
Pete000's Avatar
With its brain it sure would not run to well....
Work to Live, don't live to work...
Old 01-30-2004, 10:26 AM
JohnnieA's Avatar
datz where ya hidez da jointz
John
1988 930
Old 01-30-2004, 12:43 PM
konish's Avatar
I believe that "Lambada" is the forbidden dance...merely performing it may be illegal in this country...come on its Friday...;-)
R/
Dustin
Old 01-30-2004, 01:16 PM
nice doggie
Hetmann's Avatar
In my car that's where the amplifier sits. Perhaps you could find out how a 78 controls its Lambada frequencies....
Jerry
78 SC hotrod
02 Mini Cooper S
Old 01-30-2004, 03:32 PM
Make Bruins Great Again
Por_sha911's Avatar
If you attached an e-ram and a cool-collar to the box you can get 25% more horsepower and run 10 degrees cooler
Joe
Old 01-30-2004, 04:43 PM
What?
trj911's Avatar
I've been messing with my interior over the past month and I was wondering the same thing about that box. Now I know. Paul, thanks for asking.
Tom J.
911SC Cab
SCWDP
CaymanS
Old 01-30-2004, 04:56 PM
Bye, Bye.
Scooter's Avatar
No chip in an SC, but good try!
Elvis has left the building.
Old 01-30-2004, 04:58 PM
Monkey with a mouse
kstar's Avatar
Whatever you do, do not open that box!
BR,
Kurt
Kurt
http://starnes.com/
Old 01-30-2004, 06:39 PM
You do not have permissi
john70t's Avatar
pandora effect
Old 01-30-2004, 07:03 PM
