tried it bill, no luck
83 SC (gone) // 72 T (gone) |
damn router. can you host?
"If you're not living on the edge, then you're taking up too much space." My 1979 930 1979 930- 3.4L Andial Racing P/C's/Fuel Enrichment System/Adjustable Boost Control,Euro Fuel System,Group B Cams,K27 Turbo(1.0 Bar) Andial Intercooler, GHL Muffler/SS Header Sys,Welt. SS Kit/Camber Brace, SS Brake Lines, 350mm Momo, Billet Pedals, 9x17 - 11x17 Fikse. 1999 FXSTC- Harley Davidson HI-4 Ignition,Thunderball Cam,Mikuni 42mm,Vance & Hines 2003 Jetta Wagon GLS 1.9L TDI 1993 GMC Jimmy 4x4 St. Louis PCA - Member Kirkwood H.O.G. Chapter #2573 - Member Gateway H.O.G Chapter #1337 - Charter Member |
It'll be legen-waitforit
OK DAMNIT, I've downloaded the 3.5 patch from http://www.nd4spdworld.com/?section=util&v=5
And I'll try the game, I direct on the internet so no FW will interfere. If it works you can get me at: 68.145.247.239 give me 1 minute
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
anyone here play need for speed underground? are there any porsches in it?
i give up. gnight
Heck, I’m only 5 not 71!
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
GG's
-BILL
Yeah that's what I'm taking about...rolling, crashing, all good.
I have a custom car and someone said they couldn't see it. Is it because others don't have the graphic? I would've thought the developers would have taken this into account. And yes I need a wheel, the keyboard just doesn't cut it. I'd like to try connecting through my firewall to someone else next time (tomorrow) to make sure it works.
Q. How can I play internet games (i.e. Ages of empire) with the router? A: Enable DMZ in �Advanced Features� of the web configuration screen. For example, if your computer�s IP address is 192.168.1.102, enter the last three digits, or �102�, in the DMZ field. You may also try using the port forwarding option instead of using DMZ. try this settings change and see if it works. -BILL
Any1 around to play? 66.167.64.141 (reply to this before trying to connect)
-BILL
You still about Bill? I'll try if you are.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
ok--give a min to launch a game.
-BILL 66.167.64.141
Anything?
no luck. timed out...
try again in 2 mins
ok
connection lost. i've only managed once before so it was probably a fluke.
ok, ive tweeked some more settings....any1 here? 66.167.64.141.
(repy to this before connecting)
I'll try again.
ok-- 1min
