911 engine mods
Nubbie Questions:
1. Is there an advantage to putting 9.8:1 Euro P/C on an 83 motor? Does this mod require changes to ignition?
2. Will a 930 cam work well in an motor modded with the euro p/c.
3. Is there an advantage to using 78 heads with this motor (larger ports)?
thanks for your advice.
Old 02-05-2004, 04:00 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Re: 911 engine mods
Originally posted by astark
Nubbie Questions:
Actually it's just the pistons that are different. The advantage is better torque with slightly better horsepower. No ignition mods although twin plugging is always welcomed if you got the $$$$.
Um, well it will work, but the pistons aren't the limiting factor in changing cams, it's the cis system. And while i'm sure 930 cams will work, if sc cams are considered an upgrade in the turbo community from there 930 cams, I'd assume this would be a downgrade.
If you have the cams yes. With proper cams (such as 964, or if the cis is ditched something more radical) the early heads with larger ports will yeild better breathing room for higher horsepower at high revs.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 02-05-2004, 04:12 PM
