Gauge Lights - Are LED substitutes available?
Just burned out a tach bulb and looks like a PITA to replace. I wondered if LED's substitiutes are available instead of incandesent bulbs that don't last as long.
Yes and No.
No direct plug in LED to replace the incandesent bulbs. But, North Hollywood Speedometer shop here in L.A. will replace all your gauge lights with rows of LEDs for a truly spectacular (read: bright!!) upgrade. I haven't done this upgrade, but saw a demo from NoHoSpeedometer, and it really lights up the gauges well. A search on this board will show that some guys on this board are working on this project. Mike '86 coupe with stock (read: dull) gauge lights.
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
Movin, they are not that tough to replace if you know how to push the gauges out via the firewall. Do a search on "rotating gauges".
Audi B7 S4 |
What you think iglo inverted faces for you 911?
My personal opinion is that it will can be good. Luis |
What size are the originals? These look kind of similar...
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
By "inverted faces" do you mean white face gauges? I think they look good.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Iglo faces=electroluminescent inverted faces.
I think that it exist for 944. www.stylinconcepts.com interior>gauges>electroluminescent reverse gauge >lighted speed glo gauges |
Thanks, looks like LedTronics is on top of this issue. I don't know what type is in my '87 dash. Only reservation I have is are the LED's as bright as the originals? Second, I'll bet the dimmer switch function will be limited or not effective, either the LED's will be on or off (below a min. voltage). Any thoughts?
As for the guages, but when someone comes up with an easy. cheap, and effective upgrade to LEDs I'm there. I don't realy like the look of the EL gauge faces.
Mike Searching for a new ride '04 VW GTI 1.8T RIP ![]() '76 911S 3.0 RIP ![]() http://www.pelicanparts.com/gallery/BanjoMike |
Yes, it's my understanding that the dimmer switch won't really work for LEDs.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
do what VW does, i know they do led guages and they dim
at least our 99 passat dims |
besides, why do you need a dimmer. isnt the point of this to make them brighter?
I think all them you see lately are due to the recent "chopper" fad. It's really the Discovery Channel's fualt for exposing the "rebel" bike builder Jesse James and his shop: West Coast Choppers. The power of the idiot box. ![]() If for nothing more than a striking advertising tool or company logo, the Maltese cross variation would be a better alternative. Last edited by Eric Coffey; 02-07-2004 at 02:36 PM.. |
A much easier solution, and brighter, too ... take the old bulb out of the holder, desolder the exiting useless capsule, then solder a new GE 891 Halogen bulb (7 mm O.D.) in its' place. Then you have a brighter, dimmer-friendly bulb in place that will last a long, long time!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Swastika's? Don't go to indonesia - they have them everywhere it's a symbol of good luck and has been for God knows how long.
We stayed next door to a hotel on the island of Bali called "Swastika Bungalows". Do a google, should turn up results. Funny stuff.
Audi B7 S4 |
I am presently working on a bulb adapter that will be a plug and play set up. I will keep advised. So far, I have been doing a continious burn test to test bulb integrety with a vibration platform. Looks hopefull.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Whats wrong with a quality replacement bulbs? My car still has most of its original 17 year old bulbs with over 130,000 miles of clock time on them.
When you realize your gauges just pop out with careful extraction forces you realize its not an awful task to perform once every several years. Last edited by 350HP930; 02-08-2004 at 12:11 AM.. |
With a pair of the OEM GE bulbs currently $1.59 at the local NAPA store ... that's not a bad fix for glazed, smoky bulbs!
The GE 891 Halogen bulbs are a bit higher at $6.99 per ... but they are an 8 Watt bulb!!!
