Yellowbird RS's Avatar
Please Help Me My Lady Doesn"t Start Up
When I turn the key, the starter sounds poor. However, if I push the car, it runs perfectly.
What should I do?
Thanks for your help,
911 Carrera 1974
2.7 lts.
X/A
Old 02-06-2004, 08:12 PM
HarryD's Avatar
Hmmm..
Sounds like...
Weak Battery? What is the voltage on the battery when she is off, when she is running? Should be 12 and 13.5-14v
Corrodded battery terminals? Pull the battery cables and clean those suckers. If you have corrosion building there, this can weaken the starter.
Corroded connectors on the starter motor? Take them off and clean, if they get dirty, the flow of power to the motor is cut back.
She has been ignored for a few weeks and she needs some TLC? Drive her some more.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-06-2004, 08:30 PM
pwd72s's Avatar
Assuming it's not regulator or alternator, and you do need a new battery? You may want to take a peek at the Optima...
Old 02-06-2004, 09:03 PM
al lkosmal's Avatar
your lady?
RGruppe #669
http://www.x-faktory.com/
Old 02-06-2004, 10:02 PM
Send a message via AIM to fintstone
I agree, probably battery problem..I recommend Optima also.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 02-06-2004, 11:08 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
check all connections (battery, starter, and ground strap) and make sure they are all clean and secure. Weak battery sounds like the main problem but it's all possibly at fault since it's electronics (I don't understand it). Good luck.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 02-07-2004, 05:05 AM
First, do a load test on your battery. Test your starter. If everything is fine, i suspect a drop of voltage do to high resistance in the cricuit. It could be corrosions at contacts, worn out cables (they do wear out).
Good luck.
Phil.
Old 02-09-2004, 09:22 AM
Thanks to all
I buy a new battery (optima) and now I'm changing some old cables
X/A
Old 02-09-2004, 09:51 PM
