Upgrading to Carrera Tensioner Question
I am going to upgrade my 1983 SC to the Carrera Tensioner. Are there any other upgrades or replacements needed when I perform this. Idler arms, idler sprockets, chain ramps, ect.
Old 02-13-2004, 09:55 AM
MY83SC's Avatar
Wayne sells a "Chain Tesioner Upgrade Kit" Make sure you have everything listed there. I hope that helps!
Mike
83 SC
Old 02-13-2004, 09:57 AM
Home of the Whopper
Check the cam timing while you're in there, before you button everything back up.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 02-13-2004, 10:13 AM
HarryD's Avatar
I am no expert but I when I did my upgrade I updated the idler arms (I had the original '73s with spacers) and replaced the chain ramps (I had the old rubber ones).
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-13-2004, 10:33 AM
I just finished the tensioner upgrade on my 1980 a week ago. i followed wayne's book and the archived info on the board. it all went very smoothly.
also recommend replacing the chain ramps, since they are 20 years old and probably very brittle. i found one ramp in pieces and another one was at the bottom of the case. they cost very little to replace and if they come apart they can cause alot of damage. i think you already have the updated sprockets and arms, but check with someone else to be sure.
good luck
roger
1980 911 SC
Old 02-13-2004, 03:06 PM
Senior Member
Doug Zielke's Avatar
Ramps for sure. Your '83 will already have the upgraded idlers as OE.
(Cam timing would be a beetch to adjust with the motor in the car.)
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 02-13-2004, 03:33 PM
Home of the Whopper
Not sure on the SC’s, but cam timing is pretty easy on the long hoods. The muffler and rear engine sheet metal has to be removed, and then you have access to everything. Done it many times.
I forgot to mention to verify TDC and adjust valves first.
Good luck!
BK
Old 02-16-2004, 07:05 AM
